RF & Alpine to make "cleansweeps"
Rockfords:
3sixtyº Interactive Signal Processor
Will ship March 1, 2006
1.75" H x 7.25" W x 4.25"D
3sixty.1
-$399.99 MSRP
-$299.99 MAP
3sixty.2
-$699.99 MSRP
-$599.99 MAP
(described below)
24bit D/A
Music sensing remote turn-on
Programable Inputs
-2 to 6 channel inputs
-Up to 20v RMS input
-Channel Summing
-can accept both RCA and speaker level inputs at same time
-Signal presence and Clip indicators
Line Driver/High volt outputs
-'conservatively rated' at 5v RMS
Programable (knob) controller
-master volume/sub level
-Aux input toggle
Wireless (PDA) control interface
-Real-time control
-Your Palm OS (5.0 or better) PDA w/ Bluetooth required
EQ
-Auto Normalization with visual verification of frequency response
-Front L&R channels: 31 bands each
-Rear & Center channels: 27 bands each
-Subwoofer channel: 10 band
-Aux Input with it's own 31 band EQ
-Boost or cut +/- 10dB
X-over
-50Hz to 10kHz
-62 steps on ISO 1/3 Oct centers
-selectable 12/24dB per Octave slope
-HP/LP/BP/AP (50-200Hz LP filter on sub)
-Independent filter control for all channels
-Independent level control for all channels
-Independent muting control for all channels
Adjustable sub-sonic filter
-20 to 35Hz
-1Hz steps
Time Alignment
-10' total adjustment
-6" increments
Alpine's
PXE-H650: OEM Audio Processor
The PXE-H650 can make any factory radio sound like a high-quality Alpine unit. It is an audio processor that is designed to allow consumers to upgrade from factory sound systems. The product is a sophisticated audio processor that allows for advanced sound tuning of factory equipment by correcting the acoustical problems in any vehicle. The PXE-H650 is equipped with AntEQ™, to remove the factory equalization, and Audyssey SoundEQ XT™, to optimize the sound quality of the system.
AntEQ works by removing all factory equalization, bringing the factory system's EQ to a flat response. It balances all sound levels using DSP power, and flattens the output signals so that Alpine amplifier and speaker upgrades can be added to the factory system.
After AntEQ has flattened the factory EQ, Audyssey SoundEQ XT then tunes the vehicle's system for optimum performance. The PXE-H650 uses an active feedback microphone to collect measurements from the vehicle's cabin. The unit then tunes itself, making automatic adjustments for the in-cabin acoustics. Audyssey SoundEQ XT adjusts time correction, frequency and phase in relation to each other. At this point, Alpine amplifiers, speakers and subwoofers could be added for a simple upgrade of the factory system, or a more complex system can be made if a full multi-channel set-up is desired. A powerful DSP processor allows for acoustic correction all the way down to 20 Hz on all channels. SoundEQ XT analyzes the entire frequency spectrum, unlike most competitors' analysis of 1/3-octave solutions.
3sixty.1
-$399.99 MSRP
-$299.99 MAP
3sixty.2
-$699.99 MSRP
-$599.99 MAP
(described below)
24bit D/A
Programable Inputs
-Channel Summing
-Aux input toggle
-Real-time control
EQ
X-over
-50Hz to 10kHz
-20 to 35Hz
-1Hz steps
Time Alignment
-6" increments
Alpine's
Nice cut and paste.
Zapco has one with their DSP now built into their amps.
JL has added external summing modules and an external AUX multiplier switcher.
And I'm sure there will be more...
I hate whiners.
You know what that damn thing does?
Analog to digital conversion.
30 band digital EQ.
Auto adjusting DSP software.
Input multiplexing.
A/D conversion.
Then remote-controlled volume.
$350 is damn cheap for all that.
30 band digital EQ.
Input multiplexing.
A/D conversion.
Originally Posted by elduderino
I hate whiners.
30 band digital EQ.
Input multiplexing.
A/D conversion.
30 band digital EQ.
Input multiplexing.
A/D conversion.
thanks for your input jerkoff... i know what it does, just not something i can afford at the moment.. now maybe if they drop the price a little, then maybe i can finally get it... thats all im saying... did i say it was not worth the price??? no i did not..
Jerkoff? Jeez, you sound as old as me...
I hate whiners.
30 band digital EQ.
Input multiplexing.
A/D conversion.
30 band digital EQ.
Input multiplexing.
A/D conversion.
$350 is damn cheap
good, maybe now that there is more competition, the price can be a LITTLE more reasonable.. man 350 for JL model... ouch.. cmon tax return...
cycdaniel
Dec 17, 2019 10:58 AM
pistacio
Sep 26, 2015 09:45 AM
yahelou
Sep 6, 2015 09:12 PM
and everyone :gheyhug: :gheywave:
