CL: retaining navi functionality with after market hu
Old Mar 15, 2010 | 10:16 PM
Harlan Brown's Avatar
6th Gear
OK,
I have a 2001 acura premium with navi and am thinking about replacing my head unit. I was looking on crutchfield and when I enter my car information, there is a note that says "The factory navigation system will be lost if radio is replaced.".
I assume that this message means that I will loose the voice prompts from the navi.
Does anyone know if there are any head units that I can get that that I can keep that navigation voice prompts? My primary requirement from the head unit will be that I want it to be Ipod compatible.
Any information about replacing the head unit without loosing the navi features will be greatly appreciated.
Old Mar 15, 2010 | 10:23 PM
e30cabrio's Avatar
LFG RANGERS!!!!!!!!!!!
I replaced my nav with an aftermarket nav that I installed in the OEM nav location.
The OEM nav still works (w/o voice prompts).
FWIW the oem nav is old & slow compared to current units.
Old Mar 16, 2010 | 05:07 AM
mattastick's Avatar
Alpine's have the best Ipod connections. They're the fastest of any deck I've seen, which would include Alpine, Pioneer, Kenwood and JVC.
Old Mar 17, 2010 | 08:07 AM
OLD_HATCH's Avatar
If you find a radio that has a telephone mute signal with the audio input to go with it, it will be easily doable.
The nav unit sends a mute signal wire along with one low channel output.
If you go with an aftermarket amp that powers your inside speakers then you can buy a signal switch to swap signals via rca inputs when the nav units sends out its voice prompts.
Old Mar 18, 2010 | 11:38 PM
tangsauce's Avatar
FAQ Section
https://acurazine.com/forums/audio-video-electronics-navigation-22/d-i-y-retain-your-navi-prompts-w-aftermarket-headunit-338089/
Old Mar 19, 2010 | 12:03 AM
youngson141's Avatar
what did you end up putting there instead?
Old Mar 19, 2010 | 10:03 PM
6th Gear
Originally Posted by tangsauce
I saw that post, It looks good, except I would rather not have to solder a transister into the harness to get voice mute to work.
It is an option I am considering.
4drviper
Apr 23, 2025 07:13 PM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
lanechanger
Oct 13, 2015 10:56 AM
Cgannotti
Sep 25, 2015 05:04 PM
