CL: Remote wire and SRS light help
Old May 24, 2009 | 11:35 PM
maiku's Avatar
TSX x2
I installed my amp and sub and all i need is to tap into the fuse box, but unsure where to tap it... I tried a few, and the amp still wont turn on. Any advice? Also disconnected the acc. fuse while the car was in ignition and then a lot of the lights came on in the dash ie. check eng light, srs light, etc.. So i plugged it back in and disconnected the neg battery to reset the ECU, and now the SRS light is on... Did i do anything wrong? Please help?!!!
Old May 25, 2009 | 12:33 AM
on1wheel01's Avatar
well if u are using the stock radio and if ur cl is a 1st gen you can do what I did when i had the stock hu in. Right at the hood pop is the fuse box(well one of them) i just put it around the radio fuse. And when the radio is on the amp will be to. And your other ?'s cant help but good luck
Old May 25, 2009 | 03:39 AM
maiku's Avatar
TSX x2
Thanks im gonna see if i have that. Also i have a 2nd gen...
Old May 25, 2009 | 12:52 PM
on1wheel01's Avatar
ok well 2nd gen or not ull still have a radio fuse
Old May 26, 2009 | 02:27 AM
maiku's Avatar
TSX x2
awesome! i finally figured it out! borrowed a buddies volt meter tool, and found out my ground point wasnt in the correct spot. so the remote issue is fixed and also found a link on here on how to reset the srs light. Thank you acurazine!!!
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
oyayjoe
Jan 1, 2019 10:17 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
