TL: Radio Out
Radio Out
I just picked up my car from the dealership for a new under-dash fuse due to a starting issue. I also replaced the battery with a OEM battery while it sat on the lot.
I started it up last night and my radio will not power up. I have codes for it and normally I just enter them when I disconnect the battery for any reason, but this time no such luck. The Navi system is working fine, so I'm puzzled. Thoughts?
If it just will not accept the code look in the sticky DIY/FAQ thread...
You'll see this thread:
https://acurazine.com/forums/audio-video-electronics-navigation-22/fixed-radio-refuses-take-radio-code-700000/
Cigarette lighter isn't working, but Navi working, wipers working, defrosters working.
Just this morning on the way into work, the gauges on the instrument panel went chaotic and then shut down. At a stop sign, the engine roared as though searching for a gear while I accelerated from a stationary position.
If the cigarette lighter is out then more than likely they blew a fuse when they were fixing whatever they were fixing or they didn't catch that fuse. Normally radio and cigarette lighter are on same fuse.
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
I'd start with the fuses
Hi,
I have a 01 TL with navi.
The radio is not turning on this morning. It worked last week.
Can someone please tell me which fuse to check? I looked at the fuse box under the hood (passenger side), and I didn't see anything about the radio/head unit.
Thanks.
Thanks.
Puma Jim
20
10-20-2016 11:59 AM
SinCityTLX
20
10-19-2015 11:23 AM
jdmaszfcuk
10-19-2015 12:31 AM
dirleton
09-28-2015 04:48 PM
