TL: Radio Out
Old Oct 24, 2010 | 01:40 PM
MI99TL's Avatar
5th Gear
Radio Out
I just picked up my car from the dealership for a new under-dash fuse due to a starting issue. I also replaced the battery with a OEM battery while it sat on the lot.
I started it up last night and my radio will not power up. I have codes for it and normally I just enter them when I disconnect the battery for any reason, but this time no such luck. The Navi system is working fine, so I'm puzzled. Thoughts?
Old Oct 24, 2010 | 01:42 PM
Jonesi's Avatar
Will not power up as in no power? Or will not power up as in the code will not work?
Old Oct 24, 2010 | 01:44 PM
Jonesi's Avatar
If it just will not accept the code look in the sticky DIY/FAQ thread...
You'll see this thread:
https://acurazine.com/forums/audio-video-electronics-navigation-22/fixed-radio-refuses-take-radio-code-700000/
Old Oct 24, 2010 | 05:16 PM
MI99TL's Avatar
5th Gear
It will not power up as in no power. No message displaying code as would normally happen when power is disconnected.
Old Oct 24, 2010 | 05:38 PM
Jonesi's Avatar
Is your cigarette lighter working? Anything else you notice not working? Defrosters?
Old Oct 26, 2010 | 08:19 AM
MI99TL's Avatar
5th Gear
Cigarette lighter isn't working, but Navi working, wipers working, defrosters working.
Just this morning on the way into work, the gauges on the instrument panel went chaotic and then shut down. At a stop sign, the engine roared as though searching for a gear while I accelerated from a stationary position.
Old Oct 26, 2010 | 08:54 AM
Jonesi's Avatar
If the cigarette lighter is out then more than likely they blew a fuse when they were fixing whatever they were fixing or they didn't catch that fuse. Normally radio and cigarette lighter are on same fuse.
Old Oct 26, 2010 | 10:36 AM
fourthmeal's Avatar
Wait! This sounds like the ignition recall.
The ignition key goes defective, cuts power, just like GM cars are known to do.
Old Oct 26, 2010 | 11:49 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I'd start with the fuses
Old Apr 28, 2011 | 12:45 PM
hdp203_RENAMED's Avatar
8th Gear
Hi,
I have a 01 TL with navi.
The radio is not turning on this morning. It worked last week.
Can someone please tell me which fuse to check? I looked at the fuse box under the hood (passenger side), and I didn't see anything about the radio/head unit.
Thanks.
dirleton
Aug 6, 2024 08:19 PM
Puma Jim
20
Oct 20, 2016 11:59 AM
SinCityTLX
20
Oct 19, 2015 11:23 AM
jdmaszfcuk
Oct 19, 2015 12:31 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
