Question for VSOKOLOV NAVI conversion
Old Aug 20, 2004 | 10:22 PM
I will be doing conversion this weekend and would like to know if the system will work with my home DVD. I want to use it because its DIVX enabled.
I have power inverter and just want to be sure that the conversion kit will alow me to use it.
Old Aug 21, 2004 | 09:38 AM
bump
Old Aug 21, 2004 | 11:21 AM
vsokolov's Avatar
I have replied to your e-mail make sure you don't get static thru power inverter
Old Aug 30, 2004 | 10:34 PM
OK,
I soldered all the needed wires and the system works fine but i have one question.
Now in order for my Navi to work I need the NAVI Conversion unit to be ON all the time...
Is it possible to make NAVI bypass the conversion kit? (just in case if something happen to the kit I want to be sure that I will be able to use my NAVI)
Old Aug 31, 2004 | 03:01 AM
vsokolov's Avatar
Nothing will go wrong
Old Aug 31, 2004 | 06:18 AM
Ok, I believe you but still is there a way to use Navi if the conversion unit is off?
Old Aug 31, 2004 | 08:17 AM
Bxscig's Avatar
How do u eliminate the status thru the power provided by AC from the invertor or any AC power source?
Old Aug 31, 2004 | 10:00 AM
vsokolov's Avatar
there is no way thats why I dont like ps2
Old Aug 31, 2004 | 10:53 AM
sorry for the dumm ? but what is PS2 ?
Old Aug 31, 2004 | 10:56 AM
Bxscig's Avatar
playstation 2
Old Aug 31, 2004 | 01:16 PM
Ok, I am confused.
Why we are talking about P2 here?
Old Aug 31, 2004 | 01:43 PM
Also, Vsokolov,
Can you tell me what will be the easiest way to connect the Navi converter to 12V
Thanks.
Old Aug 31, 2004 | 08:07 PM
vsokolov's Avatar
connect to any cig lighter or if you have a tester look for power behind navi just be carefull only use computer safe tester
Old Aug 31, 2004 | 09:37 PM
Thanks.
I connected it to the cigarette lighter in my armrest.
Do you think it will be Ok if I will use the same lighter to connect my DVD ?
Old Sep 1, 2004 | 04:42 PM
Originally Posted by PhillyTL-S
Thanks.
bump
Old Sep 1, 2004 | 10:39 PM
vsokolov's Avatar
yes it will as long as that cig lighter only gets power with ignition on
BoricuaTL
Apr 8, 2016 01:08 PM
Type S Zero
Feb 17, 2016 02:37 PM
HondoGermany
23
Jan 8, 2016 03:01 PM
datadr
Sep 12, 2015 09:12 PM
ivegotthenav
Sep 11, 2015 07:51 PM
