Question for VSOKOLOV NAVI conversion
I will be doing conversion this weekend and would like to know if the system will work with my home DVD. I want to use it because its DIVX enabled.
I have power inverter and just want to be sure that the conversion kit will alow me to use it.
Originally Posted by vsokolov
I have replied to your e-mail make sure you don't get static thru power inverter
OK,
I soldered all the needed wires and the system works fine but i have one question.
Now in order for my Navi to work I need the NAVI Conversion unit to be ON all the time...
Is it possible to make NAVI bypass the conversion kit? (just in case if something happen to the kit I want to be sure that I will be able to use my NAVI)
connect to any cig lighter or if you have a tester look for power behind navi just be carefull only use computer safe tester
Thanks.
I connected it to the cigarette lighter in my armrest.
Do you think it will be Ok if I will use the same lighter to connect my DVD ?
BoricuaTL
Apr 8, 2016 01:08 PM
HondoGermany
23
Jan 8, 2016 03:01 PM
ivegotthenav
Sep 11, 2015 07:51 PM
