Question for TSX owners with amp noise
Old Mar 24, 2006 | 11:49 AM
elduderino's Avatar
VP Electricity
When you performed your interface at the inputs to the OEM amp (if you grabbed the amp output, this question isn't for you), did you attach female RCA ends at that point? And did you use regular shielded RCA or did you use twisted pair unshielded RCA?
Old Mar 24, 2006 | 12:39 PM
glott's Avatar
i've got female, regular shielded rca connectors
Old Mar 24, 2006 | 12:40 PM
elduderino's Avatar
VP Electricity
Sorry, I should have been a bit clearer.
And, what type of RCA did you run - twisted pair or regular coaxial shielded construction?
Old Mar 24, 2006 | 12:45 PM
glott's Avatar
yeah so i've got the females coming off the amp, then im using a stinger twisted pair 4 channel to my amps...still have that noise tho
Old Mar 24, 2006 | 12:57 PM
elduderino's Avatar
VP Electricity
OK, thanks.
Anyone else?
Old Mar 24, 2006 | 03:24 PM
Spoon's Avatar
When I had noise, I used solder type RCA male connectors, soldered short wires to the connectors (outside the car) then soldered those wires to the OEM wires. Used female couplers to connect to the RCA cables that run to the trunk.
No noise now, the connection is the same, except it feeds to another HU...
Old Mar 24, 2006 | 04:08 PM
elduderino's Avatar
VP Electricity
So you have no noise?
Old Mar 24, 2006 | 04:52 PM
Spoon's Avatar
No noise now.
vaughanml2
Nov 1, 2021 10:16 AM
Feb 25, 2020 09:57 AM
MyGuti
Sep 12, 2015 06:52 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
TSX 09
Sep 6, 2015 01:07 PM
