Question Regarding Head Unit 97 CL 3.0
Old Sep 12, 2006 | 12:28 AM
mybra1nhurtz's Avatar
6th Gear
Hi...im new to the community, i have questions regarding my car, i recently got this car from my parents and it had many problems already...caused by my sister .... -_-" It is a Acura 1997 CL 3.0
question is, i bought a new head unit for it, however it is not specific for the car, so basically i had to cut all the wires and try to connect them, i did that using the 2.2CL diagram and apparently i was wrong and it does not work the same way... does anyone know the diagram for the wiring on the head unit? or does anyone know the colors for the wire, thanks this would be a great help. Since i can't drive my car with my stereo sticking outta there...
Old Sep 12, 2006 | 07:39 AM
KaMLuNg's Avatar
they have wire harnesses that plug into the OEM radio plug and then those wires will connect to your head unit... but if you are going with your stock radio plug... ill post diagram after work...
Old Sep 13, 2006 | 01:26 AM
6th Gear
ack that sux, i already cut the wires off...of the plug is there any other way i can connect plugs to these oem wires to connect to aftermarket head unit?
Old Sep 13, 2006 | 05:49 PM
6th Gear
bump?
Old Sep 13, 2006 | 07:04 PM
Lajit-CL's Avatar
The12Volt.com has all the wiring diagrams and wire colors. There are two shortcuts on the site. One of them rarely works thought the second has always work for me.
Good Luck with it.
Old Sep 13, 2006 | 07:14 PM
KaMLuNg's Avatar
here u go... http://www.the12volt.com/installbay/...=1&type=Stereo
Old Sep 15, 2006 | 05:08 PM
6th Gear
anyone know where i can buy the plug then? thinking about connecting the plug back maybe it'll be easier
Old Sep 16, 2006 | 12:28 AM
TLBaller's Avatar
you can get the plug at circuit city or best buy
Old Sep 16, 2006 | 11:31 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
lemme know if you still have problems, pm me and I might be able to help you further.
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
akbears15
15
Nov 5, 2015 07:06 AM
tmux
Sep 21, 2015 05:11 PM
datadr
Sep 12, 2015 09:12 PM
