Question: Infinity Kappa powered by stock amp?
Old Apr 30, 2002 | 12:40 AM
Eggplant-EX's Avatar
Hi Silverknight............question...
I'm baaaaaaaaaaackkkk....
I was just wondering. So, I have the stock system with the amp/sub in the trunk. I still have my Infinity Kappa speakers that should fit my car. Should I replace the stocks with the Infinity Kappa.
Thanks for any help
Old Apr 30, 2002 | 01:28 AM
JaySyn77's Avatar
I'm not silverknight, but I say YES! I'm running Infinity in my car and I personally believe there's a huge difference.
Old Apr 30, 2002 | 01:15 PM
JaySyn77
are you running Infinity Kappa (2 channels) with a stock system????????????
Old Apr 30, 2002 | 01:33 PM
SilverKnight's Avatar
Retired. Not available.
Yup. You can do that. However, your output power (aka volume) may be decreased because the Bose speakers have low impedance (or so I heard) but your aftermarket speakers have high impedance (more than likely at 4Ohm). I never had stock amp powers aftermarket speakers so I dont know how much the volume will be lowered. I think it's worthed a try since I'm not proud of stock Bose speakers.
Old Apr 30, 2002 | 02:35 PM
JaySyn77's Avatar
I had the infinity speakers running off the BOSE amp for about 2 days and it sounded OK, but once you place an aftermarket amp in there...they come to life.
If you plan on staying with the stock amp...I would suggest not to place the infinity speakers in there. It's time consuming for such a small difference.
Old Apr 30, 2002 | 09:32 PM
Okay. Thanks.
Any more constructive comments????? Anyone???
Old Apr 30, 2002 | 10:54 PM
Let me change the topic so more ppl can reply. Next time, don't call me out ... just ask for help and ppl will jump in
Old May 3, 2002 | 12:56 AM
Austin519's Avatar
Eggplant-EX:
I'd put them in. Silverknight there has been some discussion...and I still have been meaning to measure the impedance of our speakers...but I do believe that the door speakers are 4 ohms. The stock sub in the TL's is like 1/2 ohm. They're most likely quieter because of a lower sensitivity...a speaker that uses a paper cone and cheap butyl rubber surrounds is a lot easier to move than the Infinity's.
Austin519
Old May 3, 2002 | 01:47 AM
I guess I will start with the rears since they are so easy to install. If I notice a difference, then I will put the fronts...
Thanks to all...
Old May 3, 2002 | 10:23 AM
Bluto's Avatar
Find beauty in dissonance
Thanks to all...
Install one in the rear. Set the fader to the rear. Use the balance to make a side-by-side comparison.
Old May 3, 2002 | 06:01 PM
Damn good idea Bluto....
Old May 22, 2002 | 03:08 PM
Steindawg's Avatar
4th Gear
BOSE
OK I am brand new to the board, my girl has recently acquired a 97 CL with the BOSE. I want to replace the headunit, and then the speakers later on. I have a 95 Maxima, with that car you can buy an adapter to use an aftermarket deck and keep the BOSE speakers and amps. Do you guys know if this is available for the CL as well? And assuming the BOSE is the same in the AC as the Max the speakers are 1ohm with the bose. So if he puts his Infinity in they will not get the sound you should from them. The resistance on the speakers will be much higher than what the system is used too. Like if your amp is bridged at 1 ohm you might have tons of RMS power, but same amp running at a 4 ohm load will only be putting out around 25% of the 1 ohm output...
Anyways thanks for any help in advance...
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
handsom-hustla
Nov 13, 2015 05:04 PM
sockr1
Oct 1, 2015 01:31 AM
Pegon95
Sep 15, 2015 01:54 PM
yahelou
Sep 6, 2015 09:12 PM
