Problem with Clarion
Old Jun 24, 2008 | 07:40 PM
italiaCLs's Avatar
9.5 lbs o' Boost!!!!
I just installed a clarion in dash screen in my car and I have a few problems with it that I am hoping i can resolve ASAP.
1. I tried putting in a DVD. the instructions say to simply put in the DVD and it will play however I only heard the movie and the diplay said "audio only" WTF!!
2. I have a annoying fuzz that is only audible when the volume is one 1. the fuzz or interference does not get louder as the volume does however it is distinctive and annoying. The fuzz is there when I play my I pod, CD, and Radio.
I have no clue what to do and would appreciate any suggestions.
Thank you.
Old Jun 24, 2008 | 08:45 PM
fuzzy02CLS's Avatar
Can't help you with that I only have their standard HU's. But they rock
Old Jun 24, 2008 | 09:12 PM
uncald4's Avatar
Former Sponsor
Thank you.
You can't see the video because either your parking brake wire is not hooked up correctly or you are not doing the correct sequence. There is a section in the instruction manual about this. You buzz is either from using the incorrect BOSE interface module or from not using any interface module at all. In this case you would be sending an amped signal from the deck into the BOSE amp. This will cause a buzz at low volume, very little range of volume and increasing distortion at medium volume.
Word?
Old Jun 25, 2008 | 09:27 AM
italiaCLs's Avatar
Which is the correct bose interface module? is that something i have to buy seperate? I know the parking brake wire is green but dont know where it goes...... Thanks for the help.
Old Jun 25, 2008 | 11:44 AM
uncald4's Avatar
Former Sponsor
If your owners manual does not reference a certain parking brake sequence then you can just ground the parking brake wire and watch video all the time. However, most newer indash screens are smarter than that. If grounding the wire doesn't allow you to watch video then you'll need to connect it to the parking brake wire on your car. If you locate your parking brake pedal or lever the wire will be at the base attached to a copper switch.
The correct module to add an aftermarket deck to your factory BOSE system is the PAC OEM-2. There are several other brand models out there but the OEM-2 is bulletproof and easy to install. You can purchase one at most car audio shops or online.
Old Jun 25, 2008 | 01:05 PM
italiaCLs's Avatar
cool. that makes it much easier. thanks for the help.
Old Jun 25, 2008 | 03:11 PM
c0v3rr1d3's Avatar
get a regular switch from like radio shack. Wire the green wire to one prong and ground wire to the other prong on the switch. Then ground the other end of the ground wire to the chasis. Flip the switch twice and u can watch video whenever u want. Will post a drawing when i can find it.
Old Jun 26, 2008 | 12:32 PM
italiaCLs's Avatar
id rather just set the parking brake wire the parking brake wire to a 12 volt source, then i can watch it anytime and wont have to buy a switch.
Old Jun 26, 2008 | 12:37 PM
uncald4's Avatar
Former Sponsor
Not a 12volt +. A Ground.
Old Jun 26, 2008 | 12:47 PM
italiaCLs's Avatar
so what do i attach it to? BTW Is the PAC OEM 2 going to stop the fuzz sound from happening??
Old Jun 26, 2008 | 01:58 PM
c0v3rr1d3's Avatar
Like unclad said its not a 12volt signal its a ground. ANd you can't wire the green wire directly to ground, it won't work. It has to be on a switch, i know i've had to do it with my clarion max675 that i got last year.
Simple 3 dollar switch, small and can mount it anywhere out of the way.
Old Jun 26, 2008 | 08:49 PM
italiaCLs's Avatar
ok cool. Now about that OEM PAC 2. FYI I dont have a aftermarket AMP. I only have stock. ALso where is the stock amp located? And finally, is the PAC 2 going to eliminate the fuzz sound..... I appreciate your help.
Old Jul 6, 2008 | 04:44 PM
chaosnexstacy's Avatar
I am pretty sure it is 12 v my pioneer has that and I just ran it to the 12v cont. now I can watch anytime I like
Old Jul 6, 2008 | 04:45 PM
Mine has 2 wires its whole usless loop thing to confuse you its funny
Old Jul 6, 2008 | 04:47 PM
trust me it can be done there is a realy funny like useless loop to it but its really easy
Old Jul 7, 2008 | 08:35 AM
c0v3rr1d3's Avatar
clarion is not 12V, its ground.. See awesome hand drawn diagram here
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
