Power Supply advice
Old May 20, 2004 | 11:01 AM
MYcarmensita's Avatar
Power Supply advice
I currently have 2 comp vr 10's with a kicker 500x2 amp and a 1 farrat rf cap. I am ugrading to 2 12 L7's with a jl 500/1 going to each. Would it be better to get a battery for the new system or just a much bigger cap?
Old May 20, 2004 | 11:02 AM
because right now when i have songs with long bass lines my kights still dim a little bit and i dont want to kill my alternator.
Old May 20, 2004 | 11:19 AM
phipark's Avatar
Not Asian
If you get a second cap, you should be fine. Keyword is "should" though.
Old May 20, 2004 | 05:33 PM
but should i maybe get a seperate battery or more powerful alternator?
Old May 20, 2004 | 10:06 PM
Hobo's Avatar
Flap.
since pro audio is no longer posting.. ill take this one up.
Capacitors and even Batteries are bandaids.
neither will solve long term power problems, the only real fix is an alternator.
Old May 21, 2004 | 03:30 PM
thanks will do can anyone give me that website that i saw before for the alternators?
Old Jun 15, 2004 | 08:43 AM
Ok check it out i have the 2.2 cl and a guy told me that they dont make alternators bigger then 150 amps for my car. The difference between 135 amps and 150 amps is like 55 bucks. Should i go for the 150 or save 50 dollars go with the 135?
Old Jun 15, 2004 | 09:20 AM
phipark's Avatar
Not Asian
Go with the 150 amp. You don't won't to be kicking yourself later on down the road.
Old Jun 15, 2004 | 09:21 AM
Ya but is it really worth 55 dollars for just 15 amps? Because i know they make 180 amp ones but according to the guy not for the 4 cylinder engines.
Jul 16, 2017 07:33 AM
spudweb
May 22, 2016 02:39 PM
knight rider
Mar 4, 2016 08:59 AM
