place to put DVD player
Old Apr 3, 2004 | 05:26 PM
iq148's Avatar
i was thinking about putting a DVD player (indash style) in the accessory compartment under the navi. this space will need to be modified. it needs to be cut but i don't know that if after i cut it, would it still be deep enough. i'm looking for a spot 7 1/2 wide, 2 1/2 high and about 10-11 inch deep.
other spots i could but the DVD player would be under the front seat or under the back deck. but i wanted something convienent.
Old Apr 4, 2004 | 03:45 PM
chadjcyr's Avatar
I'm with you...
I would like to persue the same type of install... I am looking for anyone who has accomplished installing a DIN unit while retaining the door. I think the dash loses its "lines" without the door in place. There must be a way to do it.
Old Apr 4, 2004 | 10:44 PM
21_in_az's Avatar
Do I Make You Horny?
i am trying to figure out the same thing!
also, power.......get it from the cig lighter?
Old Apr 4, 2004 | 11:53 PM
ortiz's Avatar
Don't listen to me.
I thought about it but I desided not too. But for power just hook it directly to the fuse box by the drivers door.
Old Apr 5, 2004 | 01:18 AM
Tsex on 19s's Avatar
Holla Back Youngin
how about in the arm rest... im not sure if it will fit, but i think i saw a car on this website with it done already...
Old Apr 5, 2004 | 01:10 PM
jumpper's Avatar
http://www.cardomain.com/memberpage/538412
Here is the picture I found on cardoman.com
Old Apr 5, 2004 | 10:34 PM
e_lectro's Avatar
Still here
I have a DVD player installed in my TSX and I recomend getting the install kit for the factory Tape/MP3 player. You lose the pocket, but it matches the interior perfect.
I also tried the center glove box method, but most car dvd players do not like being mounted vertically. They will play for a while, but you will notice over time that loading takes longer and it becomes more sensitive to road bumps.
Old Apr 17, 2004 | 12:08 PM
iq148's Avatar
i puchased a Pyle DVD player. it was cheap ($90) but it is only 6.25 inches wide x 2 inches high and 6.5 inches deep (without wires). you can almost fit under the nav without removing the door. it will take some modification.
i just need a way to hook up the dvd out to the stock nav without buyint the $500 tuner. i saw e_lectro's post on the converter for $125, but i don't know where to splice it.
snorf
Nov 4, 2019 06:44 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
saturno_v
Oct 28, 2015 06:57 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Aug 30, 2015 02:39 PM
