CL: Ok WTH cd player shutting off at high volume
Old Nov 25, 2009 | 12:46 PM
on1wheel01's Avatar
Ok well I had this problem in the past today i hooked up some 6.5's in the door off the hu just cuz im tired of only bass. I turned it up quite a bit and the hu shut its self off. Anyone else have this problem?
Old Nov 25, 2009 | 12:58 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
Have you tried turning it up without your rca's connected to the sub amp ?
How and when does the hu turn back on?
I had a issue like that a long time ago with a dated hu when I was trying to use all speaker outputs and all rca out puts at the same time.
Old Nov 25, 2009 | 01:45 PM
on1wheel01's Avatar
If I remember right it still does it. the only rca's hooked to a amp is the sub. And before it was the same. It's done this with 3 hu's. I imagine I wont have this problem when I hook up the speakers to the 50.4 amp. But I would like to know why it is doing it anyways
Old Nov 25, 2009 | 02:02 PM
Are they the same speakers used on all 3 HU's causing the issue.
Old Nov 25, 2009 | 02:29 PM
on1wheel01's Avatar
no diff ones
Old Nov 25, 2009 | 03:10 PM
Everytime you wired the hu's the same huh ?
Try rewiring,finding new grounding spots new asserory on wire.
Also you could check the fuses on your power wires (both,red+yellow)your using now.
Your HU's could be looking for more power thats not there to give.
Old Nov 25, 2009 | 03:17 PM
^ If thats the case it could lead to a toasted internal amp if not fixed.
I know you heard of the magic smoke from amps,same thing would apply if thats your issue
Old Nov 25, 2009 | 03:25 PM
on1wheel01's Avatar
Well i unhooked one of the 6.5's and there is no longer a problem wth is goin on lol
Old Nov 25, 2009 | 03:36 PM
so what your problem ? too low impedence or something.Comps wired incorectly?
Old Nov 25, 2009 | 03:53 PM
on1wheel01's Avatar
well there not comps just regular 6.5's and then tweets up front in stock location. Thats what i figured to low impedance but how would that be. Blah
MrHeeltoe
20
Feb 23, 2023 01:54 PM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
copmagnet82
Jun 29, 2016 08:09 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
