CL: New Deck, old speakers ??
Old Apr 16, 2010 | 12:21 PM
MrFluffy's Avatar
To many cars in my garage
Can I use my original speakers with my new pioneer deck??
Its an 01 CL-S with a bose system
Old Apr 16, 2010 | 12:28 PM
dykyy's Avatar
Yea for sure.
Old Apr 16, 2010 | 12:45 PM
tangsauce's Avatar
Yep, your stock amp will still power your speakers.
Old Apr 16, 2010 | 07:24 PM
MrFluffy's Avatar
How do I wire this
I need a wire to turn the amp on I got that but which one is it
Then I need a signal for each speaker
What Im asking is does anyone have a wiring diagram for this car
Old Apr 16, 2010 | 07:45 PM
wong05tsx's Avatar
Need more room in
Just buy the speaker harness specific for your car. The wire that turns on your amp is the wire that says "Remote" on it... It's usually blue.
Old Apr 16, 2010 | 07:59 PM
MrFluffy's Avatar
What color is it on the car not the deck
Old Apr 16, 2010 | 11:56 PM
tangsauce's Avatar
Here you go but honestly go buy a wiring harness for the cl. You'll thank us later
Old Apr 18, 2010 | 03:09 PM
Gil'sUA5's Avatar
yes it will work and it will be noticeably louder/clearer
Old Apr 20, 2010 | 11:39 PM
Tribe's Avatar
5th Gear
What if you want to replace the head unit, door speakers, and rear deck speakers on a 03- CL without adding an aftermarket amplifier? How do you wire this and any adapters /harnesses needed aside from the Honda/Acura universal harness?
Old Apr 21, 2010 | 12:16 AM
tangsauce's Avatar
Are you planning on powering the speakers with the HU? or using the factory amp? You can do either/or but I would seriously suggest if you want to replace all your speakers to buy an amp to power them, otherwise what's the point?
Aftermarket HU's signal output are weak so your speakers won't sound great and the factory amp is really only good for the bose speakers.
Old Apr 21, 2010 | 05:13 AM
mattastick's Avatar
I agree with the first part of this, but the 2nd, not so much. The 2nd part of this statement is completely speaker dependent. For example, my Eclipse 3 ways will need an aftermarket amp when I put them in (it's in shipping now, don't worry) but my buddy's Pioneer Rev's (yellow cones) don't. His car is doing 150db on 5250w clamped power (or was before he sold the amp, but it's still in the mid to high 40s on a Crossfire 1k) and his Rev's keep up just fine with power from an Alpine 9886.
Old Apr 21, 2010 | 12:12 PM
tangsauce's Avatar
Yes that's true many speakers will work fine without an amp. I'm just referring to tribe's situation in the CL. Going from stock AMP powered speakers to aftermarket DECK powered speakers might not be as good(if you can say that about bose lol) so why bother, is what my point was. Just speaking from a monetary standpoint is all. If he's gonna spend the money why not also get the appropriate amp too and make it sound better than stock.
Old May 4, 2010 | 11:27 AM
linev69's Avatar
Help anybody!!!!!!!!!!!!!! I bought Acura CL 3.0 1997, and not work stereo Bose with an amplifier. May I to put other stereo? And how? Sorry,for my English!!!!
Old May 6, 2010 | 03:26 PM
ricog102's Avatar
2001 3.2 CL type s After market radio
I am looking to install a pioneed double din 3200 in my 3.2CL. Do I need a new amp? If i use the same speakers (bose) and the factory amp will I lose any sound quality compared to t he Bose I already have in it right now?
Old May 12, 2010 | 08:56 PM
SouthPaww's Avatar
I've already got subs, amp, and a box picked out for my install. I was just wanting some more information on how to go about it. I'm thinking of keeping the stock Bose head unit I've got. (should i go aftermarket?) Would I need any kind of conversion harnesses or kits for wiring the subs and amp up to the Bose? And here's links to all the stuff I'm getting.
Subs:
http://www.onlinecarstereo.com/CarAu...ies_P1222.aspx
Amp:
http://www.onlinecarstereo.com/CarAu...KAC-9104D.aspx
Also I've got a '01 Cl-S
Old May 12, 2010 | 10:01 PM
wong05tsx's Avatar
Need more room in
Just a LOC and 2ch rca wire.. and 2 wire taps
Old May 17, 2012 | 07:35 PM
njlakeshoreg's Avatar
sorry to bring an old thread back from the dead, but instead of reasking a similar question, i am about to install a new pioneer 4400 into my 03 cl non nav with bose speakers, will it still sound good like factory??? better? worse?? if i can save the money on buying new speakers i would def like to do so, as i like the sound of the stock system, i just want xm, ipod and a a little boom boom from the trunk...
any help is great!! thanks guys!!!!!!!
Old May 18, 2012 | 09:25 AM
victus1's Avatar
It's not the deck which makes or breaks the sound....it's the speakers! Factory speakers are garbage, no matter what claims the auto maker's literature says about them.
Although that is a nice modern deck, you would get way better sound quality just by leaving in the stock head unit and installing new mid-quality speakers with a decently priced multi-channel amp.
Old Jun 19, 2012 | 07:10 PM
tjallenjr's Avatar
6th Gear
custom usualy improve oem
Old Jul 6, 2013 | 02:56 AM
street-legend's Avatar
stock bose system-1997 acura cl
I have a 1997 Acura Cl. It has a stock bose system in it. I tryed putting in a after market deck. I had power to the deck but no sound. What harness or should I say smart harness can I get that will by pass the stock amp so the deck can power my stock speakers and I can actually get sound and fully use the after market deck?
Old Aug 4, 2013 | 07:58 AM
FAMOS's Avatar
3rd Gear
THE HARNESS IS A BETTER SOLUTION BUT HERE U GO:
2001 Acura 3.2CL Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: White/Green
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Orange
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Subwoofer Speaker Positive Wire (+): White (Left and right out to the equalizer unit behind center of dash. Green for sum out to equalizer.)
Subwoofer Speaker Negative Wire (-): Orange (Left and right in from the equalizer unit. Black common.)
Subwoofer Speaker 2 Positive Wire (+): Red
Subwoofer Speaker 2 Negative Wire (-): Blue/Green
At Amplifier Harness:
Remote Turn On Input Wire: Blue
Subwoofer Speaker 1 Input Positive Wire (+): Red
Subwoofer Speaker 1 Input Negative Wire (-): Light Blue
Subwoofer Speaker 2 Input Positive Wire (+): Red
Subwoofer Speaker 2 Input Negative Wire (-): Light Blue
kb1rl
Sep 30, 2015 10:17 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
polish_pat
Sep 25, 2015 12:24 PM
rboller
Sep 23, 2015 02:49 PM
