CL: Amp swap
Old Jun 1, 2013 | 07:08 AM
loweredCL's Avatar
Amp swap
Hi all,
I'm looking to upgrade my amp and got the labels for all the wires that go into the stock am on a 2003 CL-S. The problem I see is the list does not show any input wires? It shows all the output wires to the speakers, the 12v and ground, illum, dimmer and antenna, but no inputs. Anyone have any info on this? Thanks.
Old Aug 4, 2013 | 07:49 AM
FAMOS's Avatar
3rd Gear
THIS SHOULD HELP
2001 Acura 3.2CL Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: White/Green
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Orange
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Subwoofer Speaker Positive Wire (+): White (Left and right out to the equalizer unit behind center of dash. Green for sum out to equalizer.)
Subwoofer Speaker Negative Wire (-): Orange (Left and right in from the equalizer unit. Black common.)
Subwoofer Speaker 2 Positive Wire (+): Red
Subwoofer Speaker 2 Negative Wire (-): Blue/Green
At Amplifier Harness:
Remote Turn On Input Wire: Blue
Subwoofer Speaker 1 Input Positive Wire (+): Red
Subwoofer Speaker 1 Input Negative Wire (-): Light Blue
Subwoofer Speaker 2 Input Positive Wire (+): Red
Subwoofer Speaker 2 Input Negative Wire (-): Light Blue
Old Aug 4, 2013 | 08:01 AM
loweredCL's Avatar
Originally Posted by FAMOS
THIS SHOULD HELP
Thanks, I will give it a try!!
Old Aug 4, 2013 | 01:35 PM
loweredCL's Avatar
I went in and spread out the wires at the amp, and found most wires, but were missing some, and could not find others. I was able to find 1 red wire for (+) input, but not 2, and could not find any light blue wires. I was not able to fine the 12VDC (white/green), Accessory 12VDC (white/red), found 1 orange wire but on the list there are 2, amp trigger and Sub (-). Wire colors I had left not in the list were Black with gray squares, Green with Gray squares, White/yellow with Gray squares, a yellow and a black. Your information was helpful but it looks like I need a little more help, please! I'm looking to put a better amp in but I need to know what's what before I try and wire things in. Thanks.
Old Aug 4, 2013 | 01:54 PM
loweredCL's Avatar
I need to apologize. When I looked a little deeper, there was a very good thread on wiring an 03 Cl. My fault for not doing my do diligence.... I have included it in case someone else might need it.
https://acurazine.com/forums/showthr...wiring+diagram
TypeS860
Jan 10, 2026 11:11 AM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
hpfiend
Sep 27, 2015 06:59 AM
