Need Amp Help...
Old Aug 10, 2005 | 06:11 PM
PureCrazed's Avatar
Need Amp Help...
I have (2) 8ohm speakers (JL 10w0)...
Each speaker is 125watts RMS...
I know I need to parallel wire them to drop them to 4Ohms... That would leave me with a single positive and a single negative wire coming from my box...
Questions:
1) If I get a 2-Channel amp, would I take that single pos and neg and bridge the channels?? or could I just run each 8Ohm speaker to it's own channel without parallel wiring them??
2) Should I get a 2-Channel amp that is rated (125watts x 2 @ 4Ohms RMS) or do I need to find a amp that is (125watts x 2 @ 4Ohms PEAK)
3) Would it be easier to get a mono amp so I don't have to bridge anything?? If so, what watts would I be looking for??
Also, I'm trying to spend under $200 for this amp so the cheapest amp I can get would be great... This is for my girlfriends car and she can't afford alot...
If anyone has any amp idea's with websites, please post them!! I need this amp ASAP... Trying to finish installation before I ship out (Military)...
Old Aug 10, 2005 | 06:16 PM
PureCrazed's Avatar
These are the 2 amps that I'm looking at... The first 1 is 125W per channel and the other amp is 250 bridged (125+125=250)...
Phoenix Gold Octane-R 4.0:2
* RMS Power Output: 125W x 2 @ 4 Ohm
* Peak Power Output: 250W x 2 @ 4 Ohm
* Birdged Output: 400W x 1 @ 4 Ohm
Website with Information: Here
or
Phoenix Gold Octane-R 2.5:2
* RMS Power Output: 80W x 2 @ 4 Ohm
* Peak Power Output: 160W x 2 @ 4 Ohm
* Birdged Output: 250W x 1 @ 4 Ohm
Old Aug 10, 2005 | 06:43 PM
elduderino's Avatar
VP Electricity
You would be best off with most amps bridging them and paralleling the speakers to a 4 ohm load.
When you bridge an amp each channel "sees" 1/2 the total load, so if your amp is 2 ohm stable in stereo it is 4 ohm stable in bridge mode. That will give you the max safe power for most amps.
Need? You seem, like a lot of folks today, hung up on the max power rating of the amp as the needed power to run the woofers.
If you want to run an amp bridged to that 4 ohm load and not go over 250W total, then you should get one that's rated for 250W bridged mono into 4 ohms. But I'm still not sure what your intent is.
It would be EASIER. But mono amps usually put out more power into 2 ohms than 4. From a bang for the buck standpoint you will probably get the most watts into a 4ohm load by bridging a stereo amp.
The smaller PG is probably fine for what you're doing. Not sure that it's going to have GREAT sound quality, but you won't get it for $200, and you won't hear it while you're gone anyway.
Best of luck!
Old Aug 10, 2005 | 06:53 PM
PureCrazed's Avatar
This amp is only $99.95
This amp is only $76.95
Old Aug 11, 2005 | 09:41 AM
CJams's Avatar
Guinea Pig
So basically you're saying $99.95 for 400W or $76.95 for 250W?
Drop the extra $20 bucks I say! You can never have too much amplification
Old Aug 11, 2005 | 11:03 AM
PureCrazed's Avatar
It might be $20 but my speakers are only 250W bridged... I wouldn't need the extra power and it puts my speakers at risk of blowing... Now that I'm going to parellel them and bridge the amp, the cheaper one is the way to go...
Old Aug 11, 2005 | 11:10 AM
elduderino's Avatar
VP Electricity
Your speaker are ALWAYS at risk of blowing.
The 250W rating is the rating before the amp starts to distort - NOT a hard ceiling of power output. If you abuse the system and set up the amp wrong, you can blow those subs with either amp.
Another forum member and I had a long wanking argument about this... regardless of the side you take on it, it's acknowledged that you can blow up your speaker with either of those amps (if their outputs are not total lies - whichis always possible...).
Old Aug 11, 2005 | 11:17 AM
optomos's Avatar
I=X - optomos
All ive heard about PG amps is "Stay Away"
Old Aug 11, 2005 | 10:03 PM
PureCrazed's Avatar
PG amps are used in alot of small SPL and other competitions around the mid-south where I used to live... Without going into big competitions, the price for quality is rather well I think...
Old Aug 11, 2005 | 10:09 PM
elduderino's Avatar
VP Electricity
PG used to be good. But the new stuff shares only the badge.
Old Aug 11, 2005 | 10:25 PM
2evil05's Avatar
try tind a jl 250/1 on ebay. it's 399.00 retail but you may get lucky, ifound 1 for 240.00. it's all the power you need for those spkrs.
Old Aug 12, 2005 | 09:07 AM
PureCrazed's Avatar
I don't want to spend more then $150... $200 is really pushing it... $240? nah...
It's for my girlfriends car, she doesn't need much to make her happy...
Old Aug 12, 2005 | 09:09 AM
elduderino's Avatar
VP Electricity
I don't know that I'd say that out loud about MY gf : )
Old Aug 12, 2005 | 08:48 PM
PureCrazed's Avatar
well mine doesn't know how to use a computer that well so I'm safe...
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
