Navi Converter Box Placement Idea
Old Mar 29, 2006 | 12:08 PM
fuckleberry's Avatar
This is a photochopped pic of kick panel removed and where I plan to put the RGB converter box.
The 2 red circles mark bare holes in the metal panel.
Box will be attached between the holes with either stickies or velcro.
I'm thinking of using the 2 holes to put in an additional support strap/bracket
to hold the box in place.
Can you supply some ideas on what things to use ?
Right now I'm thinking of a piece of rubber and 2 pins/rivets
thanks
Old Mar 29, 2006 | 12:17 PM
Jonesi's Avatar
I think it will be a tight enough fit that you won't need the straps..
Old Mar 29, 2006 | 12:38 PM
that's likely what they said about the space shuttle Challenger O-ring seal
Old Mar 29, 2006 | 02:17 PM
Reach's Avatar
wow... worse comparison... EVER.
Old Mar 29, 2006 | 04:33 PM
dizzy1's Avatar
I mounted the same unit vertically between the 2 holes since that is where the factory clips go in for the kick panel trim. It fits perfectly between them and against the wire harnesses. I used industrial double sided tape on the entire back. You can grab the box and almost shake the car its so well mounted with the tape. No need for screws or custom brackets.
Old Mar 29, 2006 | 05:04 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Get some double sided tape if you're really worried about it. That along with the pressure from the kick panel should hold it in place.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
oyayjoe
Jan 1, 2019 10:17 PM
ivegotthenav
Sep 11, 2015 07:51 PM
nuldabz
Sep 3, 2015 05:49 PM
