Navi Converter Box Placement Idea
This is a photochopped pic of kick panel removed and where I plan to put the RGB converter box.
The 2 red circles mark bare holes in the metal panel.
Box will be attached between the holes with either stickies or velcro.
I'm thinking of using the 2 holes to put in an additional support strap/bracket
to hold the box in place.
Can you supply some ideas on what things to use ?
Right now I'm thinking of a piece of rubber and 2 pins/rivets
thanks
I mounted the same unit vertically between the 2 holes since that is where the factory clips go in for the kick panel trim. It fits perfectly between them and against the wire harnesses. I used industrial double sided tape on the entire back. You can grab the box and almost shake the car its so well mounted with the tape. No need for screws or custom brackets.
cycdaniel
Dec 17, 2019 10:58 AM
ivegotthenav
Sep 11, 2015 07:51 PM
nuldabz
Sep 3, 2015 05:49 PM
