Nav is dark then gets brighter
Old Nov 29, 2004 | 02:39 PM
GIBSON6594's Avatar
My Garage
I searched for a solution, but found nothing. When I start my car in the morning the nav screen is very dark, like the brightness is all the way down. I check the brightness level and it is set to max. Touching the increase brightness button once increases the brightness again, but the brightness level is already at max when i touch it. It's pretty strange. Anyone heard of this before? Thanks
Old Nov 29, 2004 | 02:57 PM
SacQuacker's Avatar
Just to rule out the obvious: Are your headlights on or off ?
Old Nov 29, 2004 | 02:58 PM
GIBSON6594's Avatar
My Garage
They are off. Sorry, forgot to mention that in the first post.
Old Nov 29, 2004 | 03:05 PM
mg7726's Avatar
She said: it's GINORMOUS!
right after the Acura pic, the warning info screen does seem dim then gets bright after you press the OK button (this is with the headlights off) - on my car
Old Nov 29, 2004 | 03:21 PM
Kighter's Avatar
LCDs can be dark-ish when they are cold. They brighten up to normal once the temp raises some.
Old Nov 29, 2004 | 03:28 PM
joerockt's Avatar
Just dial 1911
This is happening to me as well. Seems to be happening because its colder. Makes sense to me though, since its LCD and the L means LIQUID. Im guessing the liquid takes a bit longer to "charge" up...
I dont think its a problem at all...
Old Nov 29, 2004 | 03:42 PM
GIBSON6594's Avatar
My Garage
Makes sense, it is getting a bit frosty here in NY. Thanks for the help peeps.
Old Nov 29, 2004 | 06:13 PM
Arcticcl9's Avatar
Can't wait to drive
This happens to me every morning. This is pretty common with LCD monitors. Your monitor just needs to warm up a bit (It does get quite warm, as a matter of fact!)
Old Nov 30, 2004 | 03:49 PM
zazen721's Avatar
where'd my wheels go?!
same here.... cold mornings in new york play havoc with my screen =) its good though because i dont want a bright screen in my face in the morning on my way to work!!
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
gatrhumpy
19
Dec 31, 2015 04:22 PM
ripit
Sep 26, 2015 06:19 PM
