TL: my stereo is going nuts
Old Nov 8, 2009 | 02:40 PM
crazyasiantl's Avatar
so on occasion, my radio will change channels by itself. say for example, its on 104.1, then it will go to 103.9 by itself, then go back.
anyone have this happen to them and what have you done to fix it?
btw its the stock Bose head unit
thanks
Old Nov 9, 2009 | 12:13 PM
Jonesi's Avatar
In over 5 years I've never heard of this issue before. Strange.. First thing I'd check is the manual knob.
Old Nov 9, 2009 | 02:53 PM
on1wheel01's Avatar
wow good times
Old Nov 9, 2009 | 03:10 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Do you have steering wheel controls? If so, take the controls apart and clean the contacts, sometimes they get corroded or flakey and can cause this
Old Nov 9, 2009 | 03:22 PM
n0rm's Avatar
I ♡ PEK PEK
^^^ X 2
If that doesn't work, take it to a priest.
Old Nov 9, 2009 | 04:28 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
If you end up needing a new factory HU PM me.I got one.
Old Nov 9, 2009 | 05:20 PM
yes, i do have steering wheel controls
is there a diy on taking apart the controls?
i was kinda thinking it might be the head unit because right when i bought the car, the previous owner had to fork out 600 bucks to get it repaired, and ive had to have it out twice for warranty work
Old Nov 9, 2009 | 06:30 PM
n0rm's Avatar
I ♡ PEK PEK
CL H/U won't work on the TL.
Old Nov 26, 2009 | 01:57 PM
AIRWOLF3's Avatar
thanks
Sounds like a sticky buttons, have you spilled anything or used cleaning stuff that may have gunk behind the keys?
Old Apr 28, 2012 | 07:34 PM
asdecorazones's Avatar
How do you take the steering wheel controls apart to clean the contacts? I've had the problem with drift described by the OP, but only two or three times since I bought my '02 TL new. But the steering wheel controls are getting increasingly flakey -- sometimes I'll go to raise the volume and the CD will move to a different track or the radio station will change instead. I want to clean the contacts but I have no idea how to go about it. Thanks for any advice.
Old Apr 29, 2012 | 10:52 AM
victus1's Avatar
You can clean the contacts with an electrical safe cleaner. I have used wd40. I sprayed a little in there between the contacts and blew out the excess with compressed air. The buttons felt and worked like new.....whereas before they were sticky. I did the same to the power window buttons. Cover your wheel with a towel so you don't get the solvent on the leather.
Old Apr 29, 2012 | 10:56 PM
Thanks! So there's no disassembly required?? I wasn't expecting it to be that easy. I'll give it a try.
4drviper
Apr 23, 2025 07:13 PM
02tljj
May 2, 2019 08:56 AM
Kamakanani0
ILX Audio, Bluetooth, Electronics & Navigation
Nov 4, 2015 05:44 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
Gianni Formica
Sep 7, 2015 08:28 PM
