Low Level Pre-Outs on 02 TL Head Unit??
Are there any low level preamp outputs on the stock 02 TL head unit???? to wire an amp and sub?
What are the stock dimensions of the speakers?
Stock RMS output per channel?
4ohm system, right?
THANKS!!!
4ohm system, right?
THANKS!!!
See this thread: https://acurazine.com/forums/car-parts-sale-361/fs-2001-acura-cl-s-steering-wheel-97802/
the preamp outs are in the small black harness. be sure to leave the common and power/ground if you want the stock sub to work.
stock HU amp is 12 watts times 4 channels.
yes, 4 ohm speakers.
if you want to pickup pre-amp signal from the stock HU, you don't absolutely need to cut the wires, you can simply tap into them so you leave the oem connexion untouched (and HU will continue to drive speaker you want it to)
every speakers are 4ohm, except the subwoofer, wich is 1ohm.
Soul_Deamon
Nov 13, 2018 04:44 PM
akbears15
15
Nov 5, 2015 07:06 AM
