keeping stock unit in cl but want amp and subs
I want to keep the stock unit in my cl but want to install my subs and amp. I want to see who is using a RCA converter in the trunk. What kind do you have and is it up to your standers? Also what wires do you have to tap into? Thanks
Jaymann107
I have a Line Output Converter (RCA Converter) that I purchased from Circuit City for close to $20.00 and have not had a problem yet. I have the wires for the LOC spliced into the rear speaker wires right before they connect to the 6x9.
You don't get highs in a sub if your crossover is set correctly. The amps should have a built in 1.
A standard line out converter will work just fine. I had a PAC one wired into the rear 6X9's as well. I have my basslink wires there now(basslink has everything built in)
May want too look at at the audio FAQ at the top of the forum as well.
i'm lost... where do you connect the remote wire to cumming off the amp? i see the wireing diagram in the how too's but how do you guys have it.....also where did you hook the brown wire? thanks
anybody know where the remote goes? i 'm guessing the radio switch? but i'm kooking it up tonight so if you can tell me where you have your connected it would help
Jaymann107
Mine was conneted to one of the fuses (Not sure which one it was with out looking at it) that is located in the fuse box by the passenger side door. Between the passenger door and the glove box.
I hope this helps.
I hope this helps.
thanks FUZZY, for some reison the pictures woldn't come up when i was reading it but i was going to tap into that wire anyway. thanks again .... I'm going to hook it up today
handsom-hustla
11-13-2015 05:04 PM
sockr1
10-01-2015 01:31 AM
Pegon95
09-15-2015 01:54 PM
yahelou
09-06-2015 09:12 PM
