TL: Jus got a 99 tl
Old Jul 30, 2010 | 11:44 PM
FREAKNBANGIN's Avatar
7th Gear
Jus got a 99 tl
Well i jus got my 99 tl so im wondering is there nething i need to watch out for when puttin in my new stereo system?
Old Aug 1, 2010 | 02:25 AM
fourthmeal's Avatar
Not much bad here. Getting the bass to the cabin requires thinking ahead. You either pull the factory sub (as I have) and let the subs in the trunk play into that, or you can do something with the ski pass. But beware cancellation effects no matter what you do (study up on trunk positioning), and a side effect of pulling the sub is that you might see white light in the sub hole through the rearview mirror at night thanks to the center-mounted stoplight. Might want to install something to keep that from happening, as it is annoying.
I recommend running active with processing, install your tweeters in the Apillar, and door speakers as big and as well deadened/sealed as you can get. Rear speakers need not be touched because the sound stage of the front should be quite convincing, especially running active with sound processing to handle the time alignment concerns you'll run into.
Head unit is a piece of cake to wire but a royal pain to get to in the first place. Do make sure you get your wiring all in the first time, nothing quite like pulling the center dash area apart TWICE because you forget a wire or two. Power wire (1/0 for me) was easy, though I do recommend techflex to protect the wire. It goes on the driver's side btw.
Old Aug 1, 2010 | 06:33 PM
7th Gear
Coo lthx which wireing harness did u use one with the rcas or without cause i was told i could use either one
Old Aug 1, 2010 | 08:53 PM
fourthmeal's Avatar
Mine was without RCA's, given there is NO reason for the factory sub on a custom system. I purchased the wiring harness and dash kit on eBay.
XxXboboXxX
Feb 16, 2005 05:00 PM
babyloc86
Aug 10, 2004 12:43 PM
