Jl Audio Clean Sweep
Old Jul 28, 2005 | 01:23 AM
g1underground's Avatar
Cosmic Cowboy
Does any know anything about this device? A salesman is trying to covince me I need this to clean the signal between the headunit, amp and speakers.
Any advice?
Old Jul 28, 2005 | 01:28 AM
Big Pimpin's Avatar
I read about this in a magazine I was gonna get it, but I used the SEARCH on this site and found out theres no point in buying it.
Old Jul 28, 2005 | 01:40 AM
Cosmic Cowboy
I tried the search here......what did you use?
Old Jul 28, 2005 | 02:38 AM
Big Pimpin's Avatar
https://acurazine.com/forums/search.php?searchid=202426
Old Jul 28, 2005 | 08:47 AM
C The "S"'s Avatar
According to some all knowing guy in here (elduderino), apparently its not necessary for the TSX, but not sure about the other cars
Old Jul 28, 2005 | 08:54 AM
optomos's Avatar
I=X - optomos
Are you putting in a whole new system?
Old Jul 28, 2005 | 09:26 AM
elduderino's Avatar
VP Electricity
Knowing that a Clean Sweep is not needed in an Acura is not "all-knowing". Just involves a little reading. Since it's more important to make a smart aleck comment that it is to answer the question, I guess your posts have more to do about posting and less to do with the actual helping.
The best adapter for the TSX and the other Acuras with preamp outputs is a pair of one-male-to-two-female RCA "Y" adapters with the male ends cut off and the cut end stripped back.
That salesman doesn't kow anything about OEM systems - and most installers don't either. That's why the Clean Sweep was invented - to try to make these ingorami more comfortable interfacing with something they don't understand. It's also a way to help with some of the cars that are more problematic than Acuras.
What car are you looking to interface with? With the TSX, we know it's not needed. For the 3G TL, there MIGHT be some EQ-ing of the signal, but probably not - it seems to be in the amp in Acuras if there is any.
Any 3G TL Portland owners who'd like to have their preamp signal tested with an RTA to show whether it's clean and flat or not, please let me know...
Old Jul 28, 2005 | 09:38 AM
stphy32's Avatar
tsxy
Originally Posted by elduderino
With the TSX, we know it's not needed. ..
My friend works for an electronic store and hes pretty knowledgable. I asked him his thoughts on the Clean Sweep and he would definitely tell me if I needed it. He said save your money. Yes it will help with other cars but you dont need it for the TSX. If you want to replace the entire system, including the head unit, tweets, stock amp, then do it. But dont waste your $ on the Clean Sweep.
Buy more JL subs and amps!!
p.s.- JL I love you and I know Clean Sweep is great, just not needed for my TSX
hahah
Old Jul 28, 2005 | 11:03 AM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
Old Jul 28, 2005 | 11:14 AM
stphy32's Avatar
tsxy
Old Jul 28, 2005 | 01:10 PM
C The "S"'s Avatar
You know I was trying to give you props on all the info you have posted about the TSX pre-amp, thats why I put your name in there in hopes that this person would look at your posts, but apparently you can't take a compliment.
Old Jul 28, 2005 | 02:29 PM
jlukja's Avatar
hahah
Please don't let my wife see this (those are my initials)
Old Jul 28, 2005 | 08:06 PM
Tsx536's Avatar
Rep'n Taxbrain.com
...Ship me your Avincar speakers, or I will spill the beans
Old Jul 28, 2005 | 08:12 PM
jlukja's Avatar
kenny
Old Jul 28, 2005 | 08:27 PM
Cosmic Cowboy
Yes, I'm looking at a JL Audio multi channel amp and Focal speakers unless I can still get the upgrade group buy for my CL but still keep the factory headunit.
The salesman is trying to say it's almost a must have with that set up, an extra 350 dollars piece.
I want to thank everyone for the responses and the knowledge you've pass on.
Just something like this gives me ammo to throw back at him
Old Jul 28, 2005 | 08:57 PM
jpswanberg's Avatar
the only time you would need a jl clean sweep is if you are going to continue to use your stock head unit and the internal signal is eq'ed to make up for crappy stock speakers. you will not need to use a clean sweep if you are using a stock head unit that is not eq'ed (tsx) or any aftermarket head unit. i don't know if your cl head unit is eq'ed or not, i would pm eld and see if he has tested a cl head unit. remember, the job of a salesperson is to make sales, not always to get you the best advice. jps
ps. i run a 300/4 and a 500/1 right now and can't say enough good things about them
Old Jul 29, 2005 | 09:24 AM
stphy32's Avatar
tsxy
what kind of car do u have?
stphy32's Avatar
tsxy
kenny
Jlukja KILLED Kenny!!!
Old Jul 29, 2005 | 09:25 AM
stphy32's Avatar
tsxy
hahahaha gosh Im so creative
Old Jul 29, 2005 | 08:30 PM
Titand19's Avatar
East Coast Boost.!
Hmm I am curious as to if maybe i could use this in my 97 pathfinder. I recently went back to the stock headunit, but I'm still running the G320 with it. It's hooked up with RCA from the front speakers via hi-lo. I wasn't sure if I should have spliced the rca's nor do i really care, but now that the topic of discussion is up, could this clean sweep business help me?
Old Jul 30, 2005 | 01:18 AM
jpswanberg's Avatar
stephy, 04 tsx.jps
hashbrown
Feb 18, 2022 11:20 AM
08KBP_VA
Oct 22, 2019 01:55 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
