interferance in PS2 install
Old May 9, 2006 | 11:17 PM
NYZGREATST's Avatar
Sig Rho's Finest
i have some sort of interferance in my ps2 install with the audio. there is this really annoying whine/ticking sound. could it be because the audio wire needs to be shielded or something?! is there anything i could use to shield the rca cables?! its annoying to the point where i want to take the thing out
reason i put it in was because my dvd player burned out so i figured for the same price i can put a PS2 in the car.
Old May 10, 2006 | 04:26 AM
GayLove's Avatar
completely rewire the whole thing, most likely bad wiring
Old May 10, 2006 | 09:07 AM
CCColtsicehockey's Avatar
Ground loop isolator
Old May 10, 2006 | 10:53 AM
NYZGREATST's Avatar
Sig Rho's Finest
whats a ground loops isolator?! i didnt hardwire my inverter, its pretty small so it fits right into my center console.
Old May 10, 2006 | 11:34 AM
NYZGREATST's Avatar
Sig Rho's Finest
i jus took it all apart and it seems the interferance is coming str8 from the headunit!! when i touch the audio inputs on the rcas that come out of the headunit, i can hear static and interferance. this has never happened before. any thoughts?!?! its so weird
Old May 10, 2006 | 12:24 PM
NYZGREATST's Avatar
Sig Rho's Finest
tried but couldnt fix it, the ps2 has a volume increaser tho, so i just put it on +2 and this way i can have the avic volume lower and i cant hear the static anymore. guess ill have to live with it
Old May 10, 2006 | 02:10 PM
CJams's Avatar
Guinea Pig
Try securing the rca connections again then put some electrical tape around each rca jacka nd see if that helps/ If the metal on the rca jack touches or is near metal it will cause that to happen sometimes.
Old May 10, 2006 | 10:31 PM
NYZGREATST's Avatar
Sig Rho's Finest
ok so the sound is so loud i cant take it. im just gonna return the ps2 after this weekend and pick up another dvd player sucksss. i tried puttting electrical tape around the ends but it didnt help at all.
Old May 10, 2006 | 10:41 PM
Jonesi's Avatar
Make sure it's not your power source/inverter.. A quick check would be to get a extension cord and run it from your house to the car.. Or try testing the PS2 on your home theatre seytem..
Returning the PS2 more then likely won't solve your problems..
Old May 10, 2006 | 10:54 PM
NYZGREATST's Avatar
Sig Rho's Finest
hmm, ok ill try that one out but when i connected the old dvd player to the unit, i had no problems. the inverter is in the center console and the rca cables are behind the headunit. would that still cause the interferance?!
Old May 10, 2006 | 11:46 PM
KaMLuNg's Avatar
especially since u said u did not hardwire the inverter in.. usually they create alot of noise...
Old May 12, 2006 | 01:04 AM
palidanx's Avatar
honk not beep
Where is the audio for the ps2 being run too? Are you running it into an snhond3 directly into the aux input for the tsx?
Old May 14, 2006 | 01:11 PM
NYZGREATST's Avatar
Sig Rho's Finest
you guys were right, it was the inverter. bought a new one and i have no problems now. thanks alot fellas.
Old May 15, 2006 | 08:38 AM
Jonesi's Avatar
Good shit...!!
Old May 15, 2006 | 06:07 PM
KaMLuNg's Avatar
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
