interferance in PS2 install
Sig Rho's Finest
i have some sort of interferance in my ps2 install with the audio. there is this really annoying whine/ticking sound. could it be because the audio wire needs to be shielded or something?! is there anything i could use to shield the rca cables?! its annoying to the point where i want to take the thing out
reason i put it in was because my dvd player burned out so i figured for the same price i can put a PS2 in the car.
Received 3,858 Likes
Ground loop isolator
Sig Rho's Finest
i jus took it all apart and it seems the interferance is coming str8 from the headunit!! when i touch the audio inputs on the rcas that come out of the headunit, i can hear static and interferance. this has never happened before. any thoughts?!?! its so weird
Sig Rho's Finest
tried but couldnt fix it, the ps2 has a volume increaser tho, so i just put it on +2 and this way i can have the avic volume lower and i cant hear the static anymore. guess ill have to live with it
Try securing the rca connections again then put some electrical tape around each rca jacka nd see if that helps/ If the metal on the rca jack touches or is near metal it will cause that to happen sometimes.
Sig Rho's Finest
ok so the sound is so loud i cant take it. im just gonna return the ps2 after this weekend and pick up another dvd player sucksss. i tried puttting electrical tape around the ends but it didnt help at all.
Make sure it's not your power source/inverter.. A quick check would be to get a extension cord and run it from your house to the car.. Or try testing the PS2 on your home theatre seytem..
Returning the PS2 more then likely won't solve your problems..
Sig Rho's Finest
hmm, ok ill try that one out but when i connected the old dvd player to the unit, i had no problems. the inverter is in the center console and the rca cables are behind the headunit. would that still cause the interferance?!
Sig Rho's Finest
Originally Posted by KaMLuNg
especially since u said u did not hardwire the inverter in.. usually they create alot of noise...
you guys were right, it was the inverter. bought a new one and i have no problems now. thanks alot fellas.
Good shit...!!
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
