Installing subs in a 99TL
Old Jun 20, 2005 | 08:27 AM
shah456's Avatar
Ok I read the DIY guide but that was not really detailed enough. I am installing two Alpine SWR-1042D 10" Type R Subs on a Alpine MRD-605 mono amp. I am keeping the stock head unit. I wanted to know where exactly the factory amp and sub is and how do I get to it. Also what gauge wires do I need to run everything. Basically I want to know exactly how to get the job done. Any help is much appreciated. Thanks.
Old Jun 20, 2005 | 09:44 AM
dark inspire's Avatar
El Presidente
Welcome!
first of all, how powerful is your amp? Second, the factory sub is behind the back passengers seat, you can't miss it. Third, you run the power wire either thru the grommet above the brake pedal or thru the side vent. You need to tkae the remote from either a fuse or from the factory amp. You will need a Line Output Converter to connect from the factory amp to the aftermarket amp.
Old Jun 20, 2005 | 09:49 AM
shah456's Avatar
Originally Posted by dark inspire
Welcome!
This is the Alpine amp I am getting Link . Do I have to take the back seat out, in order to access the amp and sub or can I get to it through the trunk. How did you run the power cable to the back so it is not showing? What kind of line output converter should I get and where do I connect that?
Old Jun 20, 2005 | 09:58 AM
El Presidente
I think a 4-guage wiring kit should be adequate. In order to access the factory sub, you need to remove the back seats. I took the long winded route and ran the power wire through the side vent over the fender well and into the car behind the fusebox. The grommet above the brake pedal is much easier. Then you take the cable and run it under the door sills all the way to the back of the car and under tthe seat, into the trunk. Line Output Converters can be bought at like Circuit City, BestBuy as well as online. You need to splice the wires from the factory amp and connect those to the LOC, and then connect RCAs from the LOC to your new amp.
Old Jun 20, 2005 | 10:03 AM
shah456's Avatar
which wires do I need to splice from the factory amp?
Old Jun 20, 2005 | 10:23 AM
El Presidente
are u sure u read a DIY? there is a diagram floating around here somewhere, I just gotta find it.
Old Jun 20, 2005 | 10:46 AM
JaredGMS's Avatar
Meat stick
Shah, no disrespect, but this does not sound like a project you should be doing without some supervision from someone with experience....remember, that if you screw something up, you could at the very least destroy your equipment, or do more damage to your car. Find someone locally who will help you do it, or take it for a professional install.....
good luck
Old Jun 20, 2005 | 12:22 PM
shah456's Avatar
good luck
My friend installed his subs in his car so I am going to have him help me but I just want to make sure I have all the information on the install before starting.
shah456's Avatar
cool just let me know if you find that diagram, it would really help.
Old Jun 20, 2005 | 01:51 PM
shah456's Avatar
This is the DIY guide I was talking about, Link
Old Jun 20, 2005 | 02:35 PM
elduderino's Avatar
VP Electricity
Seemed pretty detailed to me...
akbears15
15
Nov 5, 2015 07:06 AM
TxRzrBk
Sep 17, 2015 01:07 PM
Pegon95
Sep 15, 2015 01:54 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
alan_rich
Sep 7, 2015 11:08 PM
