CL: Installing a custom Navi/Computer System
Old Sep 24, 2009 | 01:57 AM
atrix415's Avatar
I am planning on installing a "carputer" computer system in the car. I have purchased most of the equipments but only waiting for the Double-Din LCD which will take about a week. I will post some pics of the equipments and explained what I did. But have anyon done this before on there CL or TL 01-03 and kept the stock HU? I really want to keep the stock radio or add a alpine/pioneer deck.
Old Sep 24, 2009 | 09:17 AM
Jonesi's Avatar
All you'd need is a auxillary input adapter. All you need for the headunit would be sound that I can think of..
Old Sep 25, 2009 | 04:11 AM
atrix415's Avatar
Thanks for the reply. But I forgot to mention that I will take the stock headunit off.Late decision. (02 CL-S) I did before however did the thing you said in your post. But this time I will replace the stock headunit/radio with a double-din and I to output sound from soundcard to amp/speakers. I was reading PAC might have a harness kit but don't know which one to get.
Old Sep 25, 2009 | 01:22 PM
Jonesi's Avatar
Most aftermarket headunits have axillary inputs already. Not sure what you mean by the PAC. The PAC is to keep steering wheel controls.
Old Sep 25, 2009 | 03:25 PM
mmendelzon's Avatar
how do you take out the whole kit ? where the navi, and radio is?
mmendelzon's Avatar
btw i ahve o3 tl s fully loaded
Old Sep 25, 2009 | 05:47 PM
Jonesi's Avatar
What "whole kit?"
Old Sep 25, 2009 | 10:55 PM
atrix415's Avatar
I trying to say the "PAC OEM-2" unit made by PAC however they make the steering wheel thing also. I kind of figured it out what I am trying to do. I am going to take out the stock headunit and put a double-din lcd at that location. I am not going to be installing any headunit. But I am going to be connecting my carpc to my car speakers using an aftermarket amplifier. I will wired the amp > rca > audio jack of my sound card.
Old Sep 26, 2009 | 07:51 AM
Jonesi's Avatar
Why do that instead of buying a sound card with RCA outputs?
I know LOCs work with Amps I'm not sure if they'll carry the audio you'd want becuase that would be a easy solution instead of adding a extra amp if you don't go with a headunit.
Worst case buy this $4 part
Old Sep 27, 2009 | 01:38 AM
atrix415's Avatar
yep, exactly. I guess I have to try. I am actually swapping out the stock with aftermarket alpine.
Old Oct 29, 2009 | 06:31 PM
MD03CL-S's Avatar
Any updates?
Old Oct 30, 2009 | 02:49 AM
atrix415's Avatar
Originally Posted by MD03CL-S
Any updates?
Yes, big progress. I 'completely' removed the headunit and no aftermarket install. I am in the process of installing a lilliput lcd + computer in the car. What I purchased is an metra harness kit to output sound. Here are some pictures if anyone interested I can change this thread to my 'worklog' thanks.
This process took about 1.5week (Requires: Molding, sanding, primer, sanding and about six layers of final coat of paint. I keep seeing imperfection so I lightly resand and repaint. Also spraying six layers of paint cost the bezel control port on the right to be stuck and I have to sand it with miniture filer and then another coat of paint.... here are the final pictures for the bezel.
Old Nov 4, 2009 | 06:01 PM
MD03CL-S's Avatar
Did you buy the LCD off their website or somewhere else? Also, what model did you go with?
Where are you going to put the PC in the car?
Old Nov 6, 2009 | 12:30 PM
thewhitepearl's Avatar
looks good man! more pix!!!!! im planning my install now. im thinking of doing something similar to this..http://www.teamssp.com/jt/images/001.jpg
what front end are you running?
Old Nov 7, 2009 | 03:10 AM
atrix415's Avatar
Eby701, I am going to put the PC in the trunk with a enclosure 'metal' cage I wrap with subwoofer carpeting matching the truck interior.
Old Nov 7, 2009 | 03:11 AM
atrix415's Avatar
I went with centrafuse w/ garmin gps it cost $$$ (Under XP Embedded).
The other free one is Road Runner, RR.
Old Nov 7, 2009 | 03:25 AM
atrix415's Avatar
Nice setup with the aftermarket radio. I was thinking of doing that taking out the cigarette socket and tray. I took my radio out completely. This why I have this thread.
Old Nov 8, 2009 | 05:12 PM
nice. laptop or actual pc? i'd really like to know more about you're computer setup.. where do you have it wired to? did you put it under your seat? what are you doing for a cd drive? how r u configuring it for when the car turns off? are u shutting down the computer or hibernating?
does the garmin gps interface w/the centrafuse? or is it a standalone app?
Old Nov 20, 2009 | 12:10 AM
bertyboy69's Avatar
Love to know more about the setup, more speciffically the type of PC your using i have a capruter in my TL and im not happy with the PC i have.
Old Dec 7, 2009 | 08:52 PM
MD03CL-S's Avatar
Just curious on more updates when you get a chance...
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
