Installing 2 amps to power 2 subs in CL-S
Old Feb 23, 2008 | 09:54 PM
Joshikus's Avatar
01 CL-S
Okay so I bought 2 Pioneer GM-7300M mono channel amps and 2 Pioneer 12's in a custom box from a friend who had it hooked up in a Tahoe. They each have 360 watts RMS and 800 max.
The question I have is does the alternator in the CL push out enough amps to power both of these or should I get a cap or an aftermarket alternator? Or would the stock alternator be fine? It was fine in his truck but seeing as how that is a beast of an engine compared to ours the alternator has to be pushing alot more amps than the CL.
Old Feb 23, 2008 | 10:53 PM
fuzzy02CLS's Avatar
The CLS has a 130amp alt stock. Most GM trucks have the same. Run a cap & you should be fine. If you have problems after that then look at upgrades. (Alt, 2nd battery, etc)
Also run 1-2 gauge wire to a distribution block then 4 gauge to the amps.
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Pegon95
Sep 15, 2015 01:54 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
yahelou
Sep 6, 2015 09:12 PM
