TL: installed head unit, sounds horrible
Old Jul 14, 2010 | 03:32 PM
yeedatoy's Avatar
kill you till you die
so i just installed a new head unit in my 99 tl. i expected it to sound strange without the sub working, but it sound terrible. the speakers have ear blistering highs and any bass distorts. my pos/negs are not crossed. is this normal?
Old Jul 14, 2010 | 04:25 PM
fourthmeal's Avatar
You didn't remove the Bose EQ did you.
Old Jul 14, 2010 | 04:49 PM
yeedatoy's Avatar
i unplugged it
Old Jul 14, 2010 | 05:02 PM
yeedatoy's Avatar
did i have to do anything else besides wire up the HU and unplug the EQ?
Old Jul 14, 2010 | 08:32 PM
fourthmeal's Avatar
Well that was unexpected. Mine sounded great before I added my HRU.4 amp. With the EQ completely out of the mix of course.
Make sure the new head unit is FLAT.
Old Jul 14, 2010 | 11:06 PM
yeedatoy's Avatar
hmmmmm. perhaps the head unit is damaged? i bought it used so i guess its possible. it cracks and pops randomly as well. it really sounds like the pos.negs are crossed but they aren't
Old Jul 16, 2010 | 12:14 AM
fourthmeal's Avatar
Time to bench test. Test the head unit out of the vehicle, with known good speakers.
Old Jul 18, 2010 | 06:29 AM
soupey's Avatar
3rd Gear
the stock speakers are 2ohm, if you're cranking it, expect it to cut out quite frequently. you need to change out the speakers or jus keep the volume lower.
i suggest keeping the oem bose sub hooked up through the tutorials on this forum, it'll lighten the load of pushing the bass through the oem door speakers...
Old Jul 21, 2010 | 09:52 PM
yeedatoy's Avatar
yeah, i considered that. im glad i didn't screw anything back in yet.
soupy- so would you say its normal for it to sound okay at low volume...but cut out and sound bad at lets say...the loudest volume i could go with the stock head unit? i never had a problem cranking the stock unit all the way up....which isnt loud enough for me at all. the new headunit gets real hot if i keep it at a sound level equal to stock at its loudest.
Old Jul 22, 2010 | 05:30 PM
northsidecaly's Avatar
7th Gear
ye
yea
Old Jul 22, 2010 | 10:39 PM
youngson141's Avatar
yea its normal, i got an alpine head-unit. i just set my frequency cutoff on my deck to 120hz so it only get the highs and not any low bass frequencies. sounds soo clear at all volumes but its only until i replace them with components. i also have a sub to take care of the bass the speakers aren't kicking out.
so if your head-unit has the same future as mine just set it to that or until the distortion stops.
Old Jul 26, 2010 | 09:59 PM
my.daily'tl''s Avatar
Always Working In
Most aftermarket stereos aren't designed to push 2ohm loads. The radio won't be able to handle them for long at loud volume. I'd replace the speakers or find a good four channel amp but you'll still have to replace the speakers cause I doubt they'll handle any kind of power.
Old Jul 27, 2010 | 09:43 AM
fourthmeal's Avatar
I must be raping my front stock speakers then. I have my Human Reign 4ch amp on them, Active along with a set of Dayton tweeters in the A-pillar. I have them crossed at 90hz, because they simply can't handle bass (you knew that.)
They get loud enough that's for sure.
Feb 25, 2020 09:57 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
Skirmich
Sep 15, 2015 06:41 PM
PortlandRL
Sep 14, 2015 12:01 PM
