install help on the 6.5 alpine!!!!
Old Sep 18, 2002 | 08:23 PM
fuZzBaLL143's Avatar
i have an alpine comp system type-r spr-176a. this question can go out to everyone who has a big magnet on the 6.5 . as u must know the working space for the cl is close to nil. how did u guys overcome this problem without bringing it to a custom shop? what kinda spacers and with what dimensions did you use?
Old Sep 18, 2002 | 09:41 PM
Nicky Pass's Avatar
Fuct in the hed!
Just make a wood ring out of 3/4" wood....you'll be fine. Make a cardboard template first, then trace it on to the wood, the use a jigsaw to cut it out.
Old Sep 18, 2002 | 11:36 PM
i actually tried that and also other variations of spacers, the sad thing is the magnet is always touching the window guide. also when i put enough space in between i can't put the door panel back on.
Old Sep 18, 2002 | 11:44 PM
Nicky Pass's Avatar
Fuct in the hed!
You might need to consider new speakers.
Old Sep 18, 2002 | 11:58 PM
hey nicky what is the depth of u're 6.5??
Old Sep 19, 2002 | 06:03 AM
shawhite_RENAMED's Avatar
no you dont need to consider new speakers if they wont fit in the doors get some kickpanels and install them in there..... (i have heard that the 98 and up accord kicks will fit pretty good....)
Old Sep 19, 2002 | 06:40 AM
NJ_CLS_driver's Avatar
I bought a Dremmel tool and cut the steel in the door but then I had decided I didn't want to bother and had StreetEffectz make the spacers and do the cutting.
To me the biggest pain on the car was getting the wires through the boot in the door to inside the car.
Old Sep 19, 2002 | 08:09 AM
Nicky Pass's Avatar
Fuct in the hed!
I'm not sure of the depth, It doesn't say on the JL website.....they look pretty shallow.
Old Sep 19, 2002 | 02:34 PM
spiroh's Avatar
Ive installed Focal Utopias, Rainbow Pros, Dynaudios, and I've always had the mids fit with a spacer. You are probably not doing something right. These are all 6.5 btw, and have very deep mounting depths.
spiro
Old Sep 19, 2002 | 05:04 PM
really?? whats the depth of the wood u use. my mid is actually around 3.5 inches deep and i used a ruler to c how much of a spacer i need, and it came out to around 2 inches. oh and for the kick panels, does neone have a picture of how they look in a cl and also where i can get one for a really good deal?
Old Sep 19, 2002 | 05:19 PM
Nicky Pass's Avatar
Fuct in the hed!
Kick panels would be expensive to make.....but it would be your best bet.
Old Sep 19, 2002 | 07:55 PM
does neone have the qlogic kick panels??? it says it is a 6.5, but the fine print says it can only hold a 6.25 at most. but beside that how much would a custom kick panel cost??? i don't want to spend more then 200
Old Sep 20, 2002 | 03:16 PM
hey i would think that a 6 1/2 would fit just fine but you may want to talk to valuetl on the acura-tl forum he has a pair in his tl.... so he probably could tell you better than i could... but to be honest the kickpanels would be the best bet.... no pain in the a$$ trying to run the wire thru the boot in the door no spacer needed no cutting needed.... and they are closer to equal distance from your ears which mean a more balanced sound.... just my opinion
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
TxRzrBk
Sep 17, 2015 01:07 PM
yahelou
Sep 6, 2015 09:12 PM
