IceLink, BlitzSafe, and NeoIon
Hi,
My shopping urge hit and I am looking to buy an iPod and hook it up to my 2001 CL-S with Navi. After searching through some of the posts here regarding the available interfaces, here is what I have so far:
1. IceLink. Most expensive. Delivers full functionality on steering-wheel control; charges the iPod. Some ppl have very successful installation (skyeflye), but some are having problem with full integration
2. SafeBLitz. Cheapest. But doesn't allow you to skip track on the steering wheel. Also some problems with display on the stock HU. Some conflict with navi?
3. Neo Ion. Cheaper than IceLink, but close to it. I did not see a lot of posts on this (mainly because I wasn't able to search for 3 letter words). But from few of the posts that I came across, this seems to provide all the functionalities as does IceLink. And so far what I am likley to go with.
Please share your thoughts on these units if you have experience with them. Thanks in advance.
just installed my Neo Ion today.
Oddly, it came under the "Peripheral" brand instead of Neo Ion.
Right now I could NOT get it to wrok 100% of the time.
Sometimes it will take the CD player a long time to recongize the device. And when it is recognized, sometimes I can't FF or RW songs. Key word is 'sometimes', sometimes it works, sometimes it doesnt. Maybe there is some sequence i need to follow to turn on the devices.
I was also under the impression that this will work 100% with the Nav system (read from somewhere); but i just read from Neo Ion's online manual (http://www.mp3yourcar.com/manuals/acura.pdf) that this is NOT compatible with factory Nav system. gonna dig around and call tech support.
Originally Posted by Michelin Man
i have the blitzsafe connected in my 03 tls w/ nav. sounds okay but not as good as a cd.
Does it also use the CD-changer pin at the back of the HU
Originally Posted by jit
Hi,
By the way, the USA Spec adapter does not display ID3 tags.
Originally Posted by saccorator
I recently traded in my 04 TSX with Navi. In December 05, I had the USA Spec PA-11 adapter installed. I can tell you that the install worked well. I had both it hooked up with an Ipod and the Pioneer Airware portable XM unit (since 04 models did not have standard XM). You may want to check out discountcarstereo.com. I was very impressed with the sound of the USA Spec adapter. I also have a BMW with the Ipod adapter, the USA Spec sounds much better and works the same. I had it installed with the XM adapter so it worked as if CD Changer discs 1-4 were allocated to the first four playlists and CD 5 played each song sequentially on the Ipod. CD changer disc 6 was allocated to the XM unit.
Thanks much
J
Originally Posted by 04rob
crutchfield.com says the USA SPEC PA11-HON2 won't work with 2001 CL
thanks for the info.
Do you know whether 2001 CL uses the same CD changer output as the 04 TSX?
I just got off the phone with sales rep @ crutchfield, he also said it doesn't work with CL
i might just try my luck since you had successful experience with it.
Sorry, didn't realize you had a CL. I have a TSX and don't have any experience with the CLs. Good luck though!
what made you try it tho, 'knowing' that it wasn't going to be compatible?
I've been following all of the Ipod adpater posts for months, and sometime a couple of months ago I saw someone post that it works with the TSX (sorry, can't find it right now), plus, the connector looked the same so I gave it a try.
ivegotthenav
09-11-2015 07:51 PM
Jonesi
03-23-2005 06:33 PM
