I need help with oem bose system in my CL 03
hey everyone i bought a mono amp to my cl Alpine MRD-M501
and i have a question does the oem head unit have a output for sub/amp ? if not what am i supposed to do ? please help any advice will be appreciated
there are no outputs for the amp on the OEM bose unit. you will need to use a line converter.
if you are keeping the OEM speakers/ OEM bose head unit, you will still use the little OEM bose amp and don't need to touch it
anywhere from $10-50 depending on how nice of one you want... If you're going to tie into the speaker wire after the stock amp, you're going to have to spend more for one that will handle the higher power of the amplified signal. If you're getting signal from before the factory amp, you can get the $10 cheapy at Walmart... Your choice...
i'm not using one b/c i replaced the bose head unit so i'm not sure what the high end brands are. hopefully someone here using one can recommend one for you. the last time i used one was about 10 years ago
BoricuaTL
Apr 8, 2016 01:08 PM
