How to wire the sub(s)
6MT Snob
So if the stock unit has RCA outs... I'm thinking it probably wouldnt be too bad if I used RCA Y adapters on the rear CH and ran the RCA's directly back to the amp VS using high level output converters on the 6x9's...
Thoughts, comments?
Thoughts, comments?
Don't listen to me.
Re: How to wire the sub(s)
Thoughts, comments?
Thoughts, comments?
6MT Snob
Ahh... here is where ASSuming gets you in trouble.. I ASSumed that since the ampllifer was external there were RCA's
So.. let me re-phrase my question..
Would you A> splice into and convert to RCA the line output of the HU or B> just use a line level converter on the 6X9's
Furthermore.. is the HU outputting four channels or is it just stereo line out and then the amp controls the fader/bal?
Don't listen to me.
Yes, the HU is outputting four channels.
You want me to break it?
The stock HU has 4 channels of RCA level signals going to the amp but through one of those oh so convenient light blue wiring harnesses which you will have to cut off and splice into the cut off end of an RCA cable to run to your amps if you want RCA connections - that's what I did but for all the speakers. If you're just gonna want bass from the 6X9's, then just use a LOC on their wires in the trunk- there is a crossover in the stock amp so no high signals are gonna get to your new speakers with LOC though. That's why I went through the trouble of splicing RCA cables - I can add full range speakers or do pretty much anything I want now.
I just ordered a 4 channel LOC, Im dumping the rear 6x9 and got a 10 inch sub. Im also running the the rear 6.5s off the HU. LOC was 60 dollars but its a nice one.
got my LOC today its really nicely built. i got it for 64 dollars shipped at http://www.davidnavone.com/adaptor_products.htm. they prolly make the one of the best LOC out there. mine is a 4 channel one. just a head up for those looking for one.
Future Seminole
1 Post
EDIT: the link was off, cause theres a "." after the "htm", but im still confused as to which LOC you got?? N-7785V? M-9192V? N-684V?
Future Seminole
1 Post
I got the N-774V which is a 4 channel, my amp is 4 channel. It depends on which amp you got and how you are going to use it. As for amp kit just get an 8 gauge or 4 gauge one. You can purchase it here http://www.knukonceptz.com/ They sell good stuff at reasonable choice and have premade amp kits avaliable.
Future Seminole
1 Post
thanx tuan209. i thought that an LOC was just like a premade spliced wire kinda thing with the RCA or whatever kinda connections, or are there ones like that that are just simple wires. i heard that an LOC wouldnt cost more than like 8 dollars, but i may be mistaken. what would i be looking for for a mono amp?
Future Seminole
1 Post
im not sure what my amp has. i ordered it off Ebay on saturday and stil havent gotten it. im hoping maybe ill get it tomorrow or friday so i can start to build my amp "rack". and the sub i ordered was off back order so i cancelled that and just ordered one off Ebay today. cant wait to see how my enclosure will turn out. how do you plan to make the part that holds the sub itself? with the MDF rings suspended by wooden rods, or an entire piece of MDF with the circle already cut out... not sure which would be harder to do or which will rattle..
i havent even started planning for my setup yet as im extremely busy with school, but next week is spring break so ill get a chance to look into all my options.
6MT Snob
Hey.. one more question, I know the 6x9s have a high pass, but is there a low pass as well? In other words if i use a LOC on the 6x9's for my subs am i not going to get all the low freq's ?
Don't listen to me.
Acura604
20
08-05-2017 12:55 AM
SUPRMN84
10-07-2015 09:46 PM
