How to remove back 6x9s
Old Oct 25, 2001 | 02:49 PM
HebrewNational's Avatar
I have tried but they seem really stuck. Do I need to pry the grill off or what? I would like to install my new speakers under the OEM Bose grill.
Old Oct 25, 2001 | 03:25 PM
come on who knows,
Old Oct 25, 2001 | 03:36 PM
SilverKnight's Avatar
Retired. Not available.
nope, pry off the grill is not gonna help. Wait till tonite when I get home, I'll post the instruction.
It starts in the trunk and involves the removal of the back seat too.
Old Oct 25, 2001 | 03:49 PM
Thanks!!!! TIA
Old Oct 25, 2001 | 04:17 PM
icy CL's Avatar
i'm not sure if this is what u're talking about......you need to first unscrew 2 screws for each grill from inside the trunk. these hold the grill to the rear panel shelf. when done, from the passenger cabin, pull or push the grill towards the front of the car then pull upwards....slowly but with pressure. this should remove the grill from the rear panel. to remove the 6X9s, remove the black foam ontop of the speakers, then there are 4 screws per speaker. they should be visible once you remove the grills. i would suggest detaching the wire harness first before removing the grill and speaker. hope that helps.
Old Oct 25, 2001 | 05:37 PM
Bless u my son! Any more info would still be great. I just got a nice pair of Kappas .3i and they are friggin sweet. Cruthfield wanted 250 I found em for 150 on ebay
Old Oct 25, 2001 | 06:15 PM
I dont even know Maybe I'm high
Old Oct 26, 2001 | 12:02 AM
Caddy©'s Avatar
Speaker Question
HebrewNational
I want to replace my Back Bose Speakers as well, what's a Couple good Speaker Choices I should look for on EBAY ?
Looking for 1 10 Sub and Amp as well.
Cheers
Old Oct 26, 2001 | 01:54 AM
NOLACLS's Avatar
Also the screws on the back are hex top so you will need a ratchet.
Old Oct 26, 2001 | 08:59 AM
I just bought a pair of (INFINITY KAPPA 693.3i) 6x9s. They are prob some of the best speakers for our back deck on the market. They take up to 330 watts and use a new technology for the speaker. Just do a search for that model. Crutchfield wanted 250 for the set and I found em for 145 on ebay. They is a really great Infinity BassLink 10" 200 Watt speaker available on there for 225 brand new. Just do a search for that as well. When u buy an amp for your new 6x9s make sure it has " speaker level inputs " as far as I know this means you can a tapped line in from the stock radio. Hope I was of some help. ----thanks by the way everyone for the info on taking out the back speakers!!
Old Oct 26, 2001 | 09:22 AM
NOLACLS's Avatar
I have heard the the infinity basslink really sucks...you cant really hear it.
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
james357
Feb 13, 2016 02:37 PM
