HELP! too much bass
Old Apr 2, 2006 | 04:15 PM
JDacTL's Avatar
HELP! too much bass
i installed my memphis 500watt mono amp and 2 JL 12's in my 03 TL-s two days ago. and there is way too much bass for all the time. it has a bass controller port on the side of it. do any of you know if i bought a bass controller or wutever it is called would this remedy the situation. because it does sound amazing but sometimes its jus too much bass. i.e long trips.
Old Apr 2, 2006 | 04:20 PM
dark inspire's Avatar
El Presidente
Welcome!
First of all, which JL's do you have? Second, does teh amp have a gain/boost knob? If so, where is the level at? Also, are you using the factory headunit or an aftermarket hu?
Old Apr 2, 2006 | 05:44 PM
JDacTL's Avatar
its the factory headunit. there the jl 12w1v2's and i didnt get a chance to check wut its at yet. cuase i didnt ahve time to screw around with it. i did like 90% of the install myself n then had a shop finish the rest cause i ran outa time. but the bass is good at certian points of time which is y i wanna no if it has that port if a bass control knob would work.
Old Apr 2, 2006 | 06:26 PM
El Presidente
check online if the amp has a bassknob port. maybe try messing with the crossover, if the bass is overbearing at certain frequencies as well.
Old Apr 2, 2006 | 06:46 PM
JDacTL's Avatar
yea on the website it says it has optional wired remote gain control. would that solve the problem?
Old Apr 2, 2006 | 06:51 PM
El Presidente
i think it would help, depends on what the setting is now, if the gain is at zero and you are still getting too much bass, then you would be better off changing out to one woofer.
Old Apr 2, 2006 | 11:13 PM
JDacTL's Avatar
im gonna assume that the gain is set high. i had this system in my infiniti. n it sounded underpowerd and it was off of a eclipse Navi DVD headunit. which i thought was odd that it sounds better off of this. but i did figure out that i put a switch in the remote line so i can shut it wen it pisses me off n just use the stock sub
Old Apr 3, 2006 | 12:42 AM
El Presidente
wait, so you are using both stock sub, and aftermarket subs? from my experience, that sounded a bit odd
Old Apr 3, 2006 | 08:53 AM
FL3.2TL's Avatar
Just chillen..
Well Im using the stock sub and Im using 1 12" Kicker Comp VR. The amp Im using is Power Acuostik.. Now, I have the bass knob on the amp, and Im using the factory bass control to turn the bass up and down. I heard about the switch, my friend has that in his TL, and its nice to have. Try using the knob, should work.
Old Apr 3, 2006 | 01:04 PM
JDacTL's Avatar
yea i do do that but it is insane during some songs even wen it is all the way down. and it doesnt sound odd becuase my JLs are so loud and hit so hard u cant even hear the factory sub
Old Apr 3, 2006 | 01:16 PM
Osamu's Avatar
i think the bass control knob should work. I had one on my memphis st-1000d and all the way down, my sub would bascially be off. In fact, i still have the one on my memphis, and if my friend sell the amp without the gain, i might have an extra one for sale. i'm not sure if it'll work with your memphis, but maybe?
but definitely check the gains on your amp.
and if those are all the way down (which i susupect they aren't).......if you're using a LOC or something like that, sometimes they'll have adjustible voltage, and you can turn that down too
Old Apr 3, 2006 | 03:54 PM
FL3.2TL's Avatar
Just chillen..
Thats tru, a LOC could be a reason. How did you set it up? Did you use a LOC getting the output from the stock sub? Or did you use the output from the sub directly going into the amp? If LOC, check the voltage on that, a slight turn could turn the bass up pretty good. If not, check the AMP, and turn all the knobs down, and from there work it.
Old Apr 3, 2006 | 05:18 PM
JDacTL's Avatar
LOC from the stock sub. i will check all of these things when i get a chance. thanks guys
Old Apr 3, 2006 | 06:29 PM
CJams's Avatar
Guinea Pig
hmmmm......500watts to 2 JL 12's? That sounds like there would be just enough
Old Apr 4, 2006 | 04:29 PM
JDacTL's Avatar
i set off 2 car alarms today in a parking lot at school. n 1 of the cars was about a 100 yards away. i have to say its impressive.
Old Apr 4, 2006 | 04:56 PM
PimpCL23's Avatar
contrarian in fashion
Dude theres no such thing as too much bass!!!! hahaha!! till you go deaf of course. till then let it play!!!
Old Apr 4, 2006 | 08:05 PM
JDacTL's Avatar
yea thats wut im starting to think broo.lol
Old Apr 4, 2006 | 09:59 PM
tommyt1's Avatar
well usually its the other way around when it comes to bass! You should be urging for more, but to answer your question, yes you need to purchase the bass control module. This will enable you to control the level of output from no bass to super bass! Just find a mounting point in your car and run the wire to to the amp and wa la.
Old Apr 4, 2006 | 11:00 PM
JDacTL's Avatar
cool bro thanks. yea i think thats wut i was talkin bout. it plugs into the amp correct?
Feb 25, 2020 09:57 AM
akbears15
15
Nov 5, 2015 07:06 AM
kb1rl
Sep 30, 2015 10:17 AM
Medinak12
Sep 23, 2015 07:11 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
