help getting 6 RCA inputs from stock HU
Old Apr 27, 2005 | 12:46 PM
neighbordave's Avatar
This is mainly a question for elduderino, but anyone with an answer is welcome to chime in.
I have a 2004 TSX without NAVI and am adding 2 external amplifiers. One is 4 channel and the other is a class D mono amplifier. This requires that I have two sets of full range RCA cables and one set with only low-end frequency.
I will be doing the pre-amp output install here:
https://acurazine.com/forums/audio-video-electronics-navigation-22/instructions-install-shop-preamp-output-300209/
to get the two full range RCA sets, but I still need to get the low-end set for the class D amp. Does anyone have a good way of going about this?
Thanks for your input
Old Apr 28, 2005 | 03:00 PM
anyone?
I was thinking of maybe running one of the two sets of RCA cables through my 500/1. would this work?
Any help at all would be appreciated.
Old Apr 28, 2005 | 03:11 PM
elduderino's Avatar
VP Electricity
What is the 4-channel amp?
You can run one set through the 500/1, but the fader will affect the bass channels.
What I would do is either:
1) run them into the 4-channel IF it has a mixed full-range RCA OP (the JL 300/4 does, for example). Then the 500/1 will make it bass-only with its internal xover, and you will have constant bass regardless of fader position.
2) Take the Front Left and Rear Right and run them into RCA "Y" adapters, splitting one to the 4-ch and one to the bass amp. Since you are using F and R, and L and R, to create your feed for the sub, even setting the fader all the way to the F or R, or balance all the way to one side or the other, will only cut your bass level by 3dB. Cheap constant bass regardless of fader position.
Old Apr 28, 2005 | 03:12 PM
elduderino's Avatar
VP Electricity
By the way, gimme a damn minute! : )
Old Apr 28, 2005 | 03:19 PM
The 4 channel amp is an older (`98) model Alpine V12 amp. I cant remember the exact model number and I am at work right now.
I dont think option 1 will work for me because the alpine doesnt have any outputs other than the 4 full-range speaker outputs.
I will maybe give #2 a try, although since I am pretty sure I will keep the fader centered, the 500/1 may work ok also.
Thanks for the help and sorry for being impatient
Old Apr 28, 2005 | 03:25 PM
elduderino's Avatar
VP Electricity
You might ge lucky... some of the older V12 4-channel amps had 3 pair of RCAs, including the full-range output.
GOod luck and post pics and tell us how it goes : )
Old Apr 28, 2005 | 03:30 PM
Thanks again! One last question. Where is a good place to get a quality set of RCA Y-adapters? Online or B&M, either is fine. I normally use Monster cable, but they are quite expensive.
Old Apr 28, 2005 | 04:16 PM
elduderino's Avatar
VP Electricity
Parts Express has a good selection...
Old Apr 29, 2005 | 01:30 AM
Well, it looks like you were right yet again. The Alpine is a MRV-F401 and it does have a pre-amp full range output that I can run to my JL amp. Problem solved.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
rangomango
California
Sep 24, 2015 05:47 PM
