HELP! CD stuck!!!
Old Dec 30, 2003 | 09:24 AM
LexDiamondz's Avatar
HELP! CD stuck!!!
Can anyone help me? Please?
There is a CD stuck and it won't eject, as a matter of fact none of the 6 cd's will come out or play and its making a weird noise...Err1 comes on the screen and then it goes right to the radio.......Does anyone know what I can try to do without having to go to the dealer? This is the factory Bose in CL 2.3 2001.
Old Dec 30, 2003 | 10:28 AM
Red-CL's Avatar
Doin' da crack shuffle
CL 2.3 2001
Is it still under warranty?
I would just take it to the dealer.
Old Dec 30, 2003 | 10:30 AM
No not under warranty anymore, and the dealer robs...don't want to go there.
Old Dec 30, 2003 | 07:31 PM
shawhite_RENAMED's Avatar
are you able to see the cd... if so then just take another cd and slide it on top of the stuck cd and it should come right out... i remember i use to have this problem with my stock 6 disk changer in my tl... if you cant see the cd then you are sol....
Old Dec 31, 2003 | 11:20 AM
brianlin87's Avatar
ASM I.S. Design FTW.
i had that shiet happen too many times... i fuckin hated the 6-cd changer and juss settled fer a different setup... from my experience, if you can't see the cd, ur best off holding down the eject buttom and waiting for a beep, and then all 6 cd's should eject
Old Dec 31, 2003 | 11:34 AM
SilverKnight's Avatar
Retired. Not available.
Originally posted by Red-CL
CL 2.3 2001
Do they make 2.3 in 2001?
try to take out the battery to see if the changer reset. Make sure you have the radio code and Navi code (if equipped).
Old Dec 31, 2003 | 11:42 AM
melo72's Avatar
I'm sure that he was trying to say 3.2. They stopped making the 2.3 CL in '99.
Old Dec 31, 2003 | 12:16 PM
Yes it is a 3.2
I can't see the cd, I tried to hold the eject button down, but nothing happens. There is a noise and then it goes right to the radio after reading err1
Old Dec 31, 2003 | 12:19 PM
I'll have to try to unplug the battery
Old Jan 5, 2004 | 10:56 AM
YES IT WORKED!!!!
I disconnected the battery and then when I put it back, The cd's ejected.... Thanks a lot Silverknight!
Old Jan 5, 2004 | 01:58 PM
Wow ... I'm glad to know it worked for you.
Old Jan 7, 2009 | 10:46 PM
AnthraciteBeast's Avatar
I have this exact same problem, ive tried disconnecting the battery twice and nothing. Hopefully 3rd time is the charm
Old Jan 8, 2009 | 06:23 AM
Zombie Serg's Avatar
I'll try doing this today. Otherwise, I'll just scrap the whole thing and settle for something worth like $5,000+ LMAO!
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
carz0159
Sep 20, 2015 06:11 PM
