Headunit going off and on for 01 CL-S
Old Mar 30, 2005 | 01:40 PM
Hay112's Avatar
Ok, i have a 01 acura Cl-s, and using an alpine headunit, a 4 channel jbl amp, running 100 watts to each component up front..and the back channels bridged to the sub in the back....Whenever i play a song with deep bass, when the bass hits the headunit will go off and on and yes, my lights are dimming too. So what do u guys think...my batter is less than a year old. What do u guys think? Alternator??
Also do u think if i switched to an amp that draws less power like a 3/5 that i wouln't have to change the alternator???
Old Mar 30, 2005 | 03:19 PM
Jonesi's Avatar
Have you tested the system with the volume up and no sub ?
I'd get a cap and see if that fixes your problem if not time to start digging deeper..
The cap may be a temp fix so if it does fix it I would still dig deeper..
Try a few simple tests (troubleshoot) to make sure it's a "power issue" and not a loose wire etc..
Old Mar 30, 2005 | 04:32 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Disconnect the bass amp, and see if you still experience the same problems.
Old Apr 1, 2005 | 09:13 AM
xX24Xx's Avatar
audio sq guru
Caps dont stop your lights dimming.......
Pham Alvan
May 18, 2021 06:48 AM
Soul_Deamon
Nov 13, 2018 04:44 PM
jpadilla
3G RLX (2013+)
Nov 18, 2017 07:13 PM
RSpyder
Sep 30, 2015 12:46 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
