Hard-wire Radar Detector
Old Mar 4, 2003 | 04:57 PM
sundial2k's Avatar
I just picked up my Anthracite 2003 TL-S yesterday and want to hard-wire my V1. Does anyone know if there is a switched wire up near the map lights and glasses holder to connect to or do I have to run the wire down under the dash?
Old Mar 4, 2003 | 09:08 PM
chris_wTX's Avatar
run it along the window frame, then into one of the fuse panels...works like a charm.
Old Mar 4, 2003 | 09:22 PM
Darkshear's Avatar
l33t
yep... same here... right in to the drivers side fuse junction.
Old Mar 4, 2003 | 11:47 PM
shimbo519's Avatar
USMC Butterbars
I wired mine to the fuse box and wired it with the windshield wipers...
Old Sep 9, 2003 | 03:57 PM
I have cobra.. it came with only coiled wire...where can I get the straight wire with correct jack ... did you make one yourself?
and what fuse # did you use?
Thanks,
SK
Old Sep 11, 2003 | 01:52 PM
Tom Blasing's Avatar
is the Mighty Favog
There's three wires for the wipers. Ground and power (naturally) an a third that is a signal wire. Even after I did a voltage check I tapped into the signal wire like a dumb@ss. When I put the wipers in Intermittent mode the detector would shut off and "reboot" every time the wipers made a sweep. I think that was the green or blue wire. One of those two is the WRONG ONE! you'll probably have to back-probe each one to see which one does not have a voltage drop to about 2-3 volts durring a sweep. The right wire will only drop from ~12v-13v to about 10v-11v.
I originally wanted to do the same thing as with my Talon and use a blade fuse tab with all the proper crimping of spade connectors, never had a single problem with it in the 9 years I had the car and it's still going strong. BUt i found out that our cars use Mini-blade fuses and there wasn't enough room to put the fuse back in with the tap (grrrrr). I refused to just strip teh wire and wrap it around the blade and shove it back in. I think that's so redneck-ish. So I found and tapped into the wiper "snake" where it's been working great. The dealer didn't like it but after I asked exactly why and that I understand electrical schematics, they didn't have a reply. I told them that the detector only has a 435 milliamp draw on a 20A circuit (I think), they dropped the subject. I also brought up the Magnuson-Moss Act of 1975. Again they said nothing.
This car has over sixty fuse in it (i.e.- each window for each door has it's own fuse!) so in some ways this car is a little over-engineered.
ITSJESTER
17
Dec 6, 2018 02:29 AM
chrisr
Dec 4, 2015 02:17 AM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
sockr1
Oct 1, 2015 01:31 AM
deyainrdy4ds
Sep 22, 2015 10:15 AM
