Finally took some pics of my system!!
Git er Done!!
![](http://images.cardomain.com/member_images/4/web/544000-544999/544891_15_full.jpg)
My little Sirius install in the upper pocket
![](http://images.cardomain.com/member_images/4/web/544000-544999/544891_16_full.jpg)
Eclipse EQ in the glove box
![](http://images.cardomain.com/member_images/4/web/544000-544999/544891_17_full.jpg)
Aux audio inputs down on the floor so I can hook up an MP3 player or something
![](http://images.cardomain.com/member_images/4/web/544000-544999/544891_19_full.jpg)
Custom trunk install. There is a 1.5 farad digital cap on a stand behind the left amp.
![](http://images.cardomain.com/member_images/4/web/544000-544999/544891_20_full.jpg)
My Kenwood Music Keg installed in the trim board.
![](http://images.cardomain.com/member_images/4/web/544000-544999/544891_23_full.jpg)
Sirius antenna slightly modified to fit under the brake light.
![](http://images.cardomain.com/member_images/4/web/544000-544999/544891_24_full.jpg)
I had the same rattles that everyone else had in their doors. So when I had all the door panels off I went crazy with the dynamat. Also something else that annoied me with the car are the how the door locks don't sit flush when the are locked. So I modified those when I had the panels off.
![](http://images.cardomain.com/member_images/4/web/544000-544999/544891_12_full.jpg)
![](http://images.cardomain.com/member_images/4/web/544000-544999/544891_18_full.jpg)
Git er Done!!
Originally Posted by BlackTSX
The locks look nice, im guessing with the dynomat the rattles are less? Also how do you like that music keg?
I love my music keg. This is my second one. I had one in my Integra, but that one got wrecked with the car. I have all the music that's on my computer in my car and it all gets controled through the Sirius controler so I can know what folder or song I'm on.
Use all 3 Pedals at once
I'm wondering how you modified your door lock because they too have bugged me. I was thinking of totally removing them but that would leave a hole in the panel. Looks great flush like that, how'd you do it?
Future Seminole
1 Post
thats awesome. a very nice setup. no front speaker upgrades though? i find that if i want to turn my bass up higher, i cant cause the front doors get all distorted and muddy, so out those go and in go type r components...
Still here
If you were going to go through the trouble of dynamating your doors like that, you should have used some metal sheets to fill in those large holes... would have made your door like a sealed enclouse and resulted in better sound, exp with aftermarket speakers.
Git er Done!!
Git er Done!!
Originally Posted by Deelover
satellite, 5 cd changer, and the music keg... you have enough music to listen to songs for years. I have XM and havent listened to a CD or FM since.
![Butt Head](https://acurazine.com/forums/images/smilies/butthead.gif)
I like the locks, my VW used to be like that. But on German cars, you jusy pull the inside handle and it releases the lock. Has anybody thought about what would happen if you had an electrical failure and you can't pull your locks up to get out of your car? Or even just a car accident that messed up the battery so you have no power. But atleast it looks good, I am just anal enough to do that, just so the door looks that much better.
Evil Empire Peon
One blown fuse could get you locked in your car.
Still here
Originally Posted by Revenent
Actually, that's probably why Acura/Honda didn't make it flush. It's a safety issue more than anything.
You could always make that part of your alarm system
Evil Empire Peon
You could always make that part of your alarm system ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
VP Electricity
1 Post
Actually, now you've got me thinking... an alarm backup battery, a single relay, and my driver's door switch could unlock the door even with a dead battery!
Now the question is: Do I try to get another set of wires into the door, or do I try to mount the alarm backup battery securely inside the door?
Evil Empire Peon
It might be easier to run the wires in to the panel since then you can change the batteries if necessary.
VP Electricity
1 Post
That boot doesn't seem to have much room, and I might use it all with the lock/arm/disarm wires I'm going to run in there already.
Of course, I need to remember that there is no right way to do something stupid, and my idea might be covered by that pearl of wisdom.
Git er Done!!
CGTSX2004 - Thread locker is a good thing to try but I'm not sure how well it works with plastic
As for the lock not able to be manually pulled up, I did think about that issue of not being able to get out of my car. But I did not modify the rear locks, so if I had to I could get out through the rear doors if necessary. I just had to make the locks flush in the front, because I always put my arm up there and I always used to hit my elbo on that freakin thing. I never had that problem with my Integra because the lock was with the door handle, which is how the TSX should be. Anyway I'm not that worried about electrical failure in an accident, because after my crash in my Integra everything still worked. If you haven't seen the pics of it, the driver's door was crushed into the driver's seat and the power door lock still worked.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
DiamondJoeQuimby
09-10-2015 11:40 AM
