CL: to everyone with amps
Old Jun 8, 2009 | 07:07 PM
Apham21's Avatar
where the hell are you running your power cable through to get past the firewall to get to the battery?
Ive dug around through every opening and none of them get to the engine bay.
Ive searched and someone said through the windshield wiper gromet? i could find that either.
thanks!! a picture would be nice.
Old Jun 8, 2009 | 07:10 PM
on1wheel01's Avatar
well which cl 1st or 2nd gen v6 or baby 4. I have a 97 3.0 there is a grommet on the drivers side firewall. I fit 1/0 through there plenty of room.
Old Jun 8, 2009 | 07:13 PM
Apham21's Avatar
01 cl-s v6.
Old Jun 8, 2009 | 07:59 PM
on1wheel01's Avatar
well cant help ya there dont have a 2nd gen
Old Jun 8, 2009 | 08:02 PM
chaosnexstacy's Avatar
I dont have a CL but sometimes you just have to drill a hole through the fire wall. Put a little rubber gromet around it ond your good to go. Just a suggestion if you cant find a hole. I have run some wire some crazy ways just cause I was scared to drill a little hole. now I wont hesitate to do it. Just make sure you know where you drilling.
Old Jun 8, 2009 | 08:41 PM
on1wheel01's Avatar
eh before you drill a hole some ppl run it under the car with protective hosing or duct around it. and there should be a drain plug under the spare tire you can run it up through.o personally wouldn't cut a hole in the fire wall. but hey its ur car
Old Jun 8, 2009 | 08:46 PM
mattastick's Avatar
This is what I did. It's kind of a pain, and my run of wire is longer for a 2 door coupe than some people's for their 4 door sedan, but still. It looks good, and no holes in the firewall... Although afterwards, i found out I have a spare hole in the firewall to run the wire through... Meh, whatever...
Old Jun 8, 2009 | 08:50 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
I made my own hole right above brake or gas pedal braket dont remember wich,and used a stinger 0 gauge gromet.Atempt this from the inside so you will miss the braket.Then run wire on drivers side I'll take a pic if you need.
Old Jun 8, 2009 | 11:51 PM
Apham21's Avatar
pics would be great!
i think im gonna drill and put a gromet. just need to be carefull where.
on a side note: im using a 4 gage power cable but it used to be in a BMW so the battery was in the back; therefore the guy cut it. i solder the two pieces together and heat shrinked wrapped it.... is this gonna render and watts or cause any bad problems later haha. ive solder wires plenty before, just not anything this big in gage.
Old Jun 9, 2009 | 04:21 AM
nf3d0149ab's Avatar
On the 2nd Gen CL-S...there is a hole already on the driver's side firewall..
Old Jun 9, 2009 | 09:22 AM
Jonesi's Avatar
Please atleast do research or check the DIY/FAQ link at the top of the page.. it really isn't that hard..
http://web.archive.org/web/200307131...net/sound.html
Old Jun 9, 2009 | 11:04 AM
Apham21's Avatar
i already found and looked at that. the pics didnt work for me before.
Old Jun 9, 2009 | 11:34 PM
Apham21's Avatar
does anyone have a pic of it from the engine side so i know where it comes out of?
or so i can go in reverse
Old Jun 10, 2009 | 07:39 AM
Jonesi's Avatar
Not that I know of. Maybe someone can snap a pic for you.
Old Jun 10, 2009 | 11:37 AM
SteveGunit's Avatar
9th Gear
Its not really a grommet it is more like a hole plug. Screwdriver right thru it, knock the insulation out of the way, stick the wire thru, it will feed itself right to the floor of the drivers seat.
You really have to look!
Old Jun 10, 2009 | 11:41 AM
aznboi2424's Avatar
there's a hole already there. thats where mine is. i suggest you put the seat all the way back crawl under your steering column with a flashlight and poke around there. if you still cant find it, ill post a pic for you today. i think its near the hinge of the brake pedal or something
Old Jun 10, 2009 | 11:43 AM
SteveGunit's Avatar
9th Gear
Yeah its under the bracket unit!!
Old Jun 10, 2009 | 12:01 PM
97BlackAckCL's Avatar
Regional Coordinator
(Mid-Atlantic)
I have pics from my 1st gen in my diy I made, I just used the rubber grommet where all the wires go through from under the dash into the engine bay, fit 2 x 4 Guage wires through just fine
Old Jun 10, 2009 | 01:04 PM
Apham21's Avatar
i did crawl around.... for a while haha. i found a hole by the gas pedal but i hit a wall when i put my finger in.
i found another one up by the parking break and same thing.. i hit a wall. or is this supposed to happen.. and im still just supposed to feed it in.
where is the hole from the engine point of view?
Old Jun 10, 2009 | 09:06 PM
douggiestyle's Avatar
i ran it through the front driver side fender liner comes out by the dead pedal
Old Jun 13, 2009 | 12:54 AM
slvrcrunch's Avatar
that hole that you " hit a wall" is the correct one. your actually hitting a plug that is in your engine bay. just take a good look in there, right beside the black steering assembly looking thing. sorry dont know whet exactly that is. anyway, look for that, you cant miss it and a few inches to the left of that youll see 2 plastic plugs in the firewall. take a screwdrver or whatever fits, and push through the one to the right. after that you should see a foam insert and that plug layinf in your driver side floor panel. if you cant find it just look straight back from the throttle body and a little to the right
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
