Door panel removal...
Old Oct 12, 2001 | 04:52 AM
hemoglobin23's Avatar
Hello everyone...
Hope you guys can help me out...
Well, I decided to upgrade the stock speakers, but have no idea on how to remove the door panels...How do you accomplish this?
Old Oct 12, 2001 | 01:21 PM
Brewboy's Avatar
Carefully remove plastic triangle sail panel. Remove two screws; under the large armrest and the other behind the small hinged circle behind chrome door handle in the cup. Slide door handle cup forward? about 1/2" or so to release/pull it out an inch or so. Using needle nose pliers or screwdriver, flip off small plastic clamp on metal rod connected to the door handle cup. Lift out the rod and disconnect the wiring harness to completly remove door handle cup. Gently pull the interior door panel to release the door clips on the sides and bottom. When free, lift the panel up and out of the window sill. Disconnect all the wiring harnesses. Done
Old Oct 12, 2001 | 02:04 PM
4pumpedCL's Avatar
Honkey
I think we have some of the easiest door panels to remove. The whole panel can be removed in probably less than a minute.
Old Oct 12, 2001 | 02:51 PM
2002TL's Avatar
Click here and scroll to the bottom of the page you will find instructions there.
http://www.acura-tl.com/faq.htm
Old Oct 14, 2001 | 05:24 AM
THANX!!!
cool...thanx guys...very helpful
Jul 16, 2017 07:33 AM
chasingthecool
Mar 9, 2017 05:16 PM
soupi
14
Nov 15, 2015 11:15 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
