Doing some custom electronic installs, need help
Old Aug 4, 2001 | 12:28 AM
Sniper_mjh's Avatar
How much current can be safely passed through a 22 gauge wire...
IF 250 Watt amp kits come with 8 gauge that is 20 amps, then 16 should be able to carry 10 and 32 can handle 5? Does this sound right? So 22 gauge can handle 3 amps???
thanks.. I will post pics soon...
Old Aug 4, 2001 | 12:51 AM
mr tl's Avatar
i wish i remembered. there are charts that explain that stuff
ask your question directly...what are you trying to do?
why not give it a try and see what happens with the 22 guage
Old Aug 4, 2001 | 12:53 AM
Sniper_mjh's Avatar
I just want to know how much current on a 12 V system can 22 AWG wire handle easily... I am looking for an answer of more than 3 amps
Old Aug 4, 2001 | 01:36 AM
StreetEffectz's Avatar
I would try to stay around 2 amps or under with 22 guage wire....it will get hot. If you want to use 3 amps, fuse it right at the source, but I would increase the wire size in this case just as a precaution.
Old Aug 4, 2001 | 09:44 AM
Sniper_mjh's Avatar
ok, one more question, when you are using a relay, one of the 4 pins is the positive pin, one goes to the thing you want to switch power to, one is your trigger pin and one is ground. IF i just use +12 for the trigger, and have the other pin grounded, how much current does that draw? or is it none, and the difference in voltage is what triggers the relay to switch.???
Old Oct 20, 2001 | 11:05 AM
Tripnbeats's Avatar
definetly try to stay under 2 amps or 1oowatts because 2 gauge is fairly thin, anyting more try makin it thicker
jspangan
ILX
Aug 18, 2020 11:05 AM
Feb 25, 2020 09:57 AM
Sep 17, 2015 10:16 AM
Sep 13, 2015 01:59 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
