In dash DVD install 2003 TLS
Old Jun 8, 2003 | 10:42 PM
RACINGHART03's Avatar
Question In dash DVD install 2003 TLS
Ok. So I have been reading alot about this. I wanna put an indash cd/dvd head unit in. But I wanna run the factory system(except for the sub..I gotta newly released ID MAX 10 inch and a Arc Audio CXL2500 amp{1050X1@4ohms}) I am looking at the schematic right now and I am not sure of something. Why all the confusion when it appears that PINS a8/a18 a6/a16 a5/a15 a7/a17 out of the Head unit run straight to the speakers. How come I cant run the Head unit outputs off the DVD unit right to these wires and power the factory speakers without using the eq? I know about all the hoopla regarding the panel that you need to make for the headunit and stuff. Easily solved with a piece of abs plastic and and some grey burl laminate. So regarding the wiring..am I missing something here? Please let me know. I wanna grab a PIONEER avh-p6500dvd but only If I can be sure its gonna work.
Old Jun 9, 2003 | 12:19 AM
shawhite's Avatar
you are right on target... but eventually i would suggest upgrade the stock speakers... you can use the 98 and up accord wiring harness to connect the aftermarket headunit to the stock wiring and retain use of the stock speakers... oh this will essentially bypass the stock eq as well.... my first system in the tl i used the stock door speakers but now i am upgrading everything....
Old Jun 9, 2003 | 06:44 PM
Thanks.. Where can I get the harness? Does METRA make it? Please let me know. Thanks
Old Jun 10, 2003 | 12:44 AM
shawhite's Avatar
yeah metra makes it... its the 98 and up honda accord harness...
Old Jun 10, 2003 | 08:23 PM
Thanks! I think i will be getting my TV/monitors next week and I will get underway.
cycdaniel
Dec 17, 2019 10:58 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
james357
Feb 13, 2016 02:37 PM
bymotion
Nov 18, 2015 11:28 AM
04tler
Sep 10, 2015 01:13 PM
