component speaker wiring
Old May 30, 2003 | 06:20 PM
8th Gear
Question component speaker wiring
How should one go about installing component speakers for the front? Replacing the 6-1/2" in the doors, and the mini-tweeters on the dash. Also, what is a recommended replacement? I found a nice set on crutchfield - Infinity Reference 6000cs - is this a good replacement?
When I pulled out the dash tweeter, it had really short wiring on it, preventing me from getting a good look at the wiring harness. I have noticed that there is no sound coming from any of the component tweeters - in the dash, and on the ceiling - does anyone know how these are wired?
Old May 31, 2003 | 11:08 AM
StanMan's Avatar
what car are we talking about? i believe the 2nd gen tl does not have any tweeters whatsoever...
Old May 31, 2003 | 09:40 PM
2007AcuraRL's Avatar
Yeah what car we talking about?. There are no factory tweets in 2nd generation TL. Its easy enough to add, but there are no wires up in the dash. Most people put the tweeters either in the door sail panel on a pod, or mount them on a bracket right in front of the woofer in the door, esentially making a coax design for time alignment.
Old Jun 1, 2003 | 12:13 AM
8th Gear
I have a 96 2.5TL prem, which has dash mini-tweeters, and dome light mini-tweeters. I don't think either of which are hooked up or working...
Old Jun 1, 2003 | 02:03 AM
tweeters up in the dome lights? Obviously you are not the original owner and before you bought that car someone had a system in there and raped it all out before the car was sold. You'd have to figure out if there used to be amps in there, and if so where they were mounted (under a front seat or in the trunk). depending what you are trying to do to your audio system now that you own the car, you'd probably be better off starting from scratch and run your own wiring.
Old Jun 1, 2003 | 03:38 AM
8th Gear
The 96 TL has tweeters next to the dome light, in front of the sunroof.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
