CL: CL 3.2 s type 01 Power wire Amp throw Firewall
I have a CL 3,2 s type 01 and I cant find any holes to run my amp wire throw the firewall.
Dont want to drill a hole!!
Any ideas or know a hole i can put it throw plz help thx??????????????????
By the way i put in a new stereo, had a Bose and i hear everyone talking about if you take out ur Bose ur sub that you have in your window wont work, well i put in my stereo in myself and the sub works !!!!
wow. wow. wow.
Check the DIY thread under 2nd gen CL and "adding an amp"..
Might want to do some more searching while you are there.. Considering there isn't a sub in the CL only in the TL.
B A N N E D
generally speaking where most shops/individuals like to drill is just right of the dead pedal, there is a hole indented in the firewall where the clutch pedal/master cylinder goes if it was a manual, it is open on both sides, and a direct shot down the framerail from the battery (since it is normally said that, the shortest run of the power cable is the best)
I have an 03 CLS6, I don't know if it's the same as the '01, but there is a pre-drilled hole in the firewall. It's a little hard to explain, if you stick your head down where the pedals are and look up, about a couple inches up from the gas-pedal's mount, there is a hole that's covered with insulation (the insulation cap is about an inch diameter). Remove the insulation, and stick a screwdriver through it to see it from the engine bay.
Are you serious? It's the sticky thread at the top of the A/V forum. The very first one that says "---------------->> **Audio/Video - DIY, Info and FAQ - All Models ** <<------------"
cycdaniel
12-17-2019 10:58 AM
handsom-hustla
11-13-2015 05:04 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
