Car would not start! now radio says "code" Help please.
Old Apr 14, 2009 | 03:10 PM
max240's Avatar
Hey guys, So I drove home the other day, parked car in garage, then had to go back out about 30 mins later. The car would not start or turn over at all. It finally started. the yesterday it would not start at all again after filling up at the gas station. Several attempst with nothing. I did find corosion on the positive terminal of the battery and cleaned off best I could.--still wouldn't start. A few minutes/attempts later the car started just perfectly. Now the radio says code and will not play any cd's or the radio at all. Any suggestions? Thanks much guys.
Old Apr 14, 2009 | 03:18 PM
sho_nuff1997's Avatar
I disagree with unanimity
You need to punch in the security code. It may be written inside the owner's manual or the folder that the manual is in.
If you don't know it or can't find it, the dealer can unlock it for you.
Old Apr 14, 2009 | 03:20 PM
max240's Avatar
ok. I'll try to track that down and try that. Any idea why the car would not start at all? There was NO power whatsoever. Thanks for the response...
Old Apr 14, 2009 | 03:32 PM
Were any lights on when you tried to start the car? Any sounds?
Old Apr 14, 2009 | 03:41 PM
max240's Avatar
No. Nothing at all. It was completely dead. then a few minutes and several attempts later, it fired up immediately as it usually does.
Old Apr 14, 2009 | 03:42 PM
nayaab88's Avatar
Check for loose battery terminal.
Old Apr 14, 2009 | 03:53 PM
max240's Avatar
i checked that... it seemed to be on tight but there was quite a bit of corrosion. I cleaned it off, but it still did not start at first.
Old Apr 15, 2009 | 04:29 AM
bodacious253's Avatar
this was happend to my car. i think mines from my tranny after i got it replaced. i guess when its not in park all the way it wont start. when it happens again try turning the key to the second notch step on the break and move the shift nob if it dont move out of park try wiggiling it then try to start it up
Old Apr 15, 2009 | 09:25 AM
Wish I Had A TL's Avatar
Cool
If you cant find the code, you can call the Acura Dealer, and make sure you have the car VIN, give it to them, and they can give it to you. They may tell you they cant, but they can, I did, No problems.
Old Apr 15, 2009 | 01:49 PM
Bearcat94's Avatar
AZ Community Team
You can also try registering at:
http://owners.acura.com/landing.aspx
When I logged in there, all my car info was available, including radio and/or navi codes.
Not sure, but you may need to call Corp Cust Service to get registered.
Old Apr 15, 2009 | 04:12 PM
max240's Avatar
Thanks for the help guys. I found the code and got the radio reset. BUT, now the cd player will not work. the door/flap that opens to allow loading or ejecting cd's is open and it just flashes an error code at me whenever I try to do anything cd related. sucks, cuz there are cd's in there right now. any suggestions or experience with this problem? thanks again guys.
Old Apr 15, 2009 | 04:26 PM
Unplug the car battery and reset the radio
There might be a reset button on the radio some where. Maybe a tiny hole you need to stick a paper clip in.
Old Apr 15, 2009 | 05:44 PM
Bob_F's Avatar
You might be seeing a jammed CD problem. Search the forum for a pile of possible fixes. One possible fix is to smack the dash near the radio. Another one involves sticking a nail-file or the like in the CD slot.
Also, if your starting problems continue, consider a possible ignition switch problem.
Old Apr 15, 2009 | 09:32 PM
Cool
Another fix seems to hit right at the "A" on the radio.
Old Apr 16, 2009 | 11:41 PM
newperson's Avatar
There's no Acura in
I used to use another CD to get stuck CDs out. Basically play with the eject button while sticking the spare CD to help with ejection. Since CDs are plastic, seems less obtrusive than a nail file or something with a sharp edge, or striking the assembly.
Old Apr 17, 2009 | 11:35 PM
Bearcat94's Avatar
AZ Community Team
....Another one involves sticking a nail-file or the like in the CD slot.
Got yer fix right here:
https://acurazine.com/forums/showthr...highlight=nail
Feb 25, 2020 09:57 AM
TLrascal
Aug 3, 2018 11:00 PM
handsom-hustla
Nov 13, 2015 05:04 PM
jordanboi
Sep 5, 2015 01:33 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
