Car would not start! now radio says "code" Help please.
Hey guys, So I drove home the other day, parked car in garage, then had to go back out about 30 mins later. The car would not start or turn over at all. It finally started. the yesterday it would not start at all again after filling up at the gas station. Several attempst with nothing. I did find corosion on the positive terminal of the battery and cleaned off best I could.--still wouldn't start. A few minutes/attempts later the car started just perfectly. Now the radio says code and will not play any cd's or the radio at all. Any suggestions? Thanks much guys.
ok. I'll try to track that down and try that. Any idea why the car would not start at all? There was NO power whatsoever. Thanks for the response...
this was happend to my car. i think mines from my tranny after i got it replaced. i guess when its not in park all the way it wont start. when it happens again try turning the key to the second notch step on the break and move the shift nob if it dont move out of park try wiggiling it then try to start it up
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
If you cant find the code, you can call the Acura Dealer, and make sure you have the car VIN, give it to them, and they can give it to you. They may tell you they cant, but they can, I did, No problems.
AZ Community Team
Received 7,770 Likes
You can also try registering at:
http://owners.acura.com/landing.aspx
When I logged in there, all my car info was available, including radio and/or navi codes.
Not sure, but you may need to call Corp Cust Service to get registered.
Thanks for the help guys. I found the code and got the radio reset. BUT, now the cd player will not work. the door/flap that opens to allow loading or ejecting cd's is open and it just flashes an error code at me whenever I try to do anything cd related. sucks, cuz there are cd's in there right now. any suggestions or experience with this problem? thanks again guys.
I disagree with unanimity
Unplug the car battery and reset the radio
There might be a reset button on the radio some where. Maybe a tiny hole you need to stick a paper clip in.
Also, if your starting problems continue, consider a possible ignition switch problem.
You might be seeing a jammed CD problem. Search the forum for a pile of possible fixes. One possible fix is to smack the dash near the radio. Another one involves sticking a nail-file or the like in the CD slot.
There's no Acura in
I used to use another CD to get stuck CDs out. Basically play with the eject button while sticking the spare CD to help with ejection. Since CDs are plastic, seems less obtrusive than a nail file or something with a sharp edge, or striking the assembly.
AZ Community Team
handsom-hustla
11-13-2015 05:04 PM
